BL Media Player Internet Audio NOT Playing
  • BL Media Player Internet Audio NOT Playing
    Just playing yesterday with BLMediaplayer on one touchscreen. I could not stream local audio from
    mms://a1149.l1305038288.c13050.g.lm.akamaistream.net/D/1149/13050/v0001/reflector:38288
    Works locally on HS server with Windows Media Player but gets the following error when trying to play from "playlist" with BLMedia Player.
    3/21/2010 6:38:24 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    3/21/2010 6:38:25 AM  Error  Playing media on Media Player, File 'mms://a1149.l1305038288.c13050.g.lm.akamaistream.net/D/1149/13050/v0001/reflector:38288' not found.
    3/21/2010 6:38:25 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    3/21/2010 6:38:26 AM  Error  Playing media on Media Player, File 'mms://a1149.l1305038288.c13050.g.lm.akamaistream.net/D/1149/13050/v0001/reflector:38288' not found.
    3/21/2010 6:38:26 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    3/21/2010 6:38:27 AM  Error  Playing media on Media Player, File 'mms://a1149.l1305038288.c13050.g.lm.akamaistream.net/D/1149/13050/v0001/reflector:38288' not found.
    3/21/2010 6:38:27 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    3/21/2010 6:38:28 AM  Error  Playing media on Media Player, File 'mms://a1149.l1305038288.c13050.g.lm.akamaistream.net/D/1149/13050/v0001/reflector:38288' not found.
    3/21/2010 6:38:28 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    Just changed the link to:
    http://www.bbc.co.uk/worldservice/meta/tx/nb/live/ennws.asx
    With the same results in the log:
    /21/2010 7:18:25 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    3/21/2010 7:18:26 AM  Error  Playing media on Media Player, File 'http://www.bbc.co.uk/worldservice/meta/tx/nb/live/ennws.asx' not found.
    3/21/2010 7:18:26 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    3/21/2010 7:18:27 AM  Error  Playing media on Media Player, File 'http://www.bbc.co.uk/worldservice/meta/tx/nb/live/ennws.asx' not found.
    3/21/2010 7:18:27 AM  BLMediaPlayer Info  Speaker Client (ICS-HS-2:DEFAULT) is playing!
    I re-initialized playlist before attempt on second try. I can play this streaming audio link with MS Media player on the HS box though. No issues with local music playlists.
    - Pete
    Auto mator
    HS4 Pro - V4.0.5.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    When I wrote this I di not even have this in mind but some people have managed to get it working. Hopefully they will chime in.
    Cheers,
    Bob
      Hello Bob,
      It was working for me. Years ago it was just a palmpad event which would load a mediaplayer event. Using your application I would be able to do the same with streaming internet audio on various PC's (and touchscreens) around the house. Another concern is when I exited the browser and returned to the BLMediaplayer GUI to shut it off it HS ends up going into an endless loop. Please note that I do not typically use HS as a means to serve up internet audio but as stated your application did work for me for specific audio streams historically and it currently does not.
      - Pete
      Auto mator
      HS4 Lite -
        Should I assume that my concern will not be addressed and utilize something else?
        - Pete
        Auto mator
        HS4 Lite -
          I have no idea why it does not work.
          You would have to capture me a debug log of the issue occurring and log a help desk ticket on my site.
          I am fighting off a virus right now so I will not be digging into it until I am feeling better
          Cheers,
          Bob
