BLPlex - Broken
    #16
    I've sent my logs for .21 still same problem for me. The PI "sees" the players, but will not create the HS devices for them.
    RJ_Make On YouTube
      #17
      It only creates them when you play something. If you see a list of players with checkboxes next to them - check one - go play something. The devices get created then. For me.
        #18
        Thanks, but unfortunately not working for me.
        Sent from my LM-G820 using Tapatalk
        RJ_Make On YouTube
          #19
          still broken here
            #20
            Are you running the newest beta?
            If so then I need you to capture a debug log of the startup of the plugin
            1. Disable plugin
            2. Edit hspi_BLPlex.ini and change debugLevel=true and save INI file
            3. Restart plugin
            Let it run for a minute and then disable debug logging
            Email me the debug log zipped
            blade9123 at gmail dot com
            Cheers,
            Bob
              #21
              1. Disable plugin
              3. Restart plugin
              Will do tonight. thx
                #22
                Blade oddly, it started working. I had the PI disabled for 2 weeks so I'll keep it on for a while and monitor it.
                btw, is there any way to send on-screen notifications from HS to Plex clients? I miss being able to pop-up messages on the screen like I could with Kodi.
                thanks
                  #23
                  Trying to set it up. Using the beta version, but no devices shows up and no token given.
                  Could it be the two factor auth login that messes this up?
                  2.15.2021 20:43:11
                  Legacy-Plugin
                  BLPlex
                  Initialization complete for Plex Media Server
                  2.15.2021 20:43:08
                  Legacy-Plugin
                  BLPlex
                  Initializing Plex Media Server...
                  2.15.2021 20:31:39
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:31:35
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:29:26
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:29:22
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:24:38
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:24:35
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:24:29
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:24:25
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:20:44
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:20:41
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:19:15
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:19:10
                  Legacy-Plugin
                  BLPlex
                  2.15.2021 20:31:37
                  Legacy-Plugin
                  BLPlex start
                  BLPlex plugin has been initialized
                  2.15.2021 20:31:35
                  Legacy-Plugin
                  BLPlex start
                  BLPlex Debug Logging is Enabled!
                  2.15.2021 20:31:35
                  Legacy-Plugin
                  BLPlex start
                  Loaded configuration successfully
                  2.15.2021 20:31:35
                  Legacy-Plugin
                  BLPlex start
                  Initializing BLPlex...
                  2.15.2021 20:31:35
                  Legacy-Plugin
                  BLPlex start
                  BLPlex version is: 2.0.21.0
                  2.15.2021 20:24:27
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:24:25
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:24:25
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:24:25
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:17:36
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:17:34
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:17:34
                  Legacy-Plugin
                  BLPlex start
                  2.15.2021 20:17:34
                  Legacy-Plugin
                  BLPlex start
                  BLPlex version is: 2.0.20.0
                  2.15.2021 20:26:40
                  Legacy-Plugin
                  BLPlex Info
                  BLPlex Debug Logging Enabled!
                  General Options
                  Debug Logging
                  Plex Server Options
                  Status Initialized Initialize Plex Server Token:
                  Plex Server IP Address xxxxxxxxx
                  Plex Server Port 32400
                  Plex User Email xxx@xxx.xxx
                  Plex User Password xxxxxx
                  Polling Options
                  Number Of Seconds to Poll For Sessions This is the number of seconds that the plug-in will poll the Plex Media Server for active sessions.
                  Get Lyrics From Plex
                  Device Options
                  Show Last Played Media When Player is Stopped
                  Logging Options
                  Log Plex Server Activity
                  Note: This will log all activity from the Plex Media Server to the HomeSeer Log (now playing, etc).
                  This allows the user to specify which Plex Devices will be enabled in the plug-in.
                  The enabled Plex Devices will have devices created and will be tracked by the plug-in
                  Delete Disabled Devices
                  Name Product Device Platform
                  Total Devices: 0
                    #24
                    It was the two factor auth that was causing the problem.
                      #25
                      One of my plex players has been discovered and added to my devices. The other two are not being detected. I'm emailing the log file...
                      Any help is much appreciated!
                      pace
