CasaTunes TTS
  • CasaTunes TTS
    Are there plans to update the CasaTunes plugin to support the newly released CasaTunes TTS capabilities?
    https://www.casatunes.com/features/tts
    added to my TODO list
      Great! Thank you.
        In version 3.0.0.11 available in the beta section of the updater, I have added "Speak" and "Play chime" event actions
          Thanks again!! I haven't tested it out yet, but this should be perfect.
            The CasaTunes plug-in is working great.
            BUT - I can't seem to get the TTS to work at all.
            I'm sure I just missed something in setup.
            Is anyone using this and could you give me a little guidance.
            Thanks...
              Bump
                I keep getting a repeating error on CasaTunes plug-in -
                Sep-20 12:24:25 PMCasaTunesERROR System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond 192.168.10.217:20321 at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at HSPI_CasaTunes.Zone.DownloadImage(Uri imageUri)
                The IP address & port do not exist on my network. I'm not sure where they came from or how to reset them???
                Also - the TTS doesn't work (which may be related)
                Any help???
                  Any help???
                  this error means the plugin failed to download an artwork image, the IP Address and port are part of an url sent to the plugin by CasaTunes, so I'm not sure why it would send an url that does not exist on your network, I would need to see a full debug log to investigate more.
