Connetion Error
  • Connetion Error
    spud
    Would you be able to help diagnosis some connection errors?
    For awhile now I have been getting errors in my log as you can see below. When I run the command "wget http://10.1.80.11:8735/api/v1/sources" from my Homeseer Linux machine I get the following. Therefore, I don't believe it is a connection issue as this appears to be the valid JSON response.
    [{"Hidden":false,"IsShared":true,"Name":"Unknown Source","MediaTypesSupported":61696,"Type":1,"SourceType":6,"SourceID":
    0,"ExternalDeviceType":0},{"Hidden":false,"IsShared":false,"Name":"Adults","MediaTypesSupported":61696,"Type":1,"SourceT
    ype":6,"SourceID":1,"ExternalDeviceType":0},{"Hidden":false,"IsShared":false,"Name":"Background","MediaTypesSupported":6
    1696,"Type":1,"SourceType":6,"SourceID":2,"ExternalDeviceType":0},{"Hidden":true,"IsShared":false,"Name":"Source4","Medi
    aTypesSupported":0,"Type":0,"SourceType":0,"SourceID":3,"ExternalDeviceType":0},{"Hidden":false,"IsShared":false,"Name":
    "SoundMachine","MediaTypesSupported":0,"Type":4,"SourceType":9,"SourceID":4,"ExternalDeviceType":0,"ExternalDeviceImageI
    D":"Unknown","AndroidLaunchURL":"","iOSLaunchURL":""},{"Hidden":true,"IsShared":false,"Name":"Source6","MediaTypesSuppor
    ted":0,"Type":0,"SourceType":0,"SourceID":5,"ExternalDeviceType":0}]
    The following are the errors from my logs.
    In addition it might be a nice feature to have a device that shows the status of the plugin. Some of my other plugins have a device that shows the connection status to the device (Alarm Panel, Irrigation controller, etc.) Therefore, I can setup an alert when the connection goes down or if there is an error with the plugin.
    Aug-15 12:43:11 PM CasaTunes DEBUG System.NullReferenceException: Object reference not set to an instance of an object at HSPI_CasaTunes.CasaTunesApp.PollZones (System.Object source, System.Timers.ElapsedEventArgs e) [0x0002b] in :0
    Aug-15 12:43:11 PM CasaTunes ERROR PollZones Object reference not set to an instance of an object
    Aug-15 12:43:11 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/sources
    Aug-15 12:43:11 PM CasaTunes ERROR System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in :0 at System.Net.HttpWebRequest.GetResponse () [0x00016] in :0 at HSPI_CasaTunes.CasaAPI`1[T].Execute (System.String MethodType, System.String BaseURL, System.String Method, System.Collections.Generic.Dictionary`2[TKey,TValue] Parameters, System.String Payload) [0x000ce] in :0
    Aug-15 12:43:09 PM CasaTunes DEBUG System.NullReferenceException: Object reference not set to an instance of an object at HSPI_CasaTunes.Zone+<>c__DisplayClass70_0. b__0 (HSPI_CasaTunes.RESTSource src) [0x00006] in :0 at System.Collections.Generic.List`1[T].Find (System.Predicate`1[T] match) [0x0000d] in <7b0d87324cab49bf96eac679025e77d1>:0 at HSPI_CasaTunes.Zone.PollZone (System.Object sender, System.Timers.ElapsedEventArgs e) [0x00232] in :0
    Aug-15 12:43:09 PM CasaTunes ERROR PollZones Object reference not set to an instance of an object
    Aug-15 12:43:09 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/3/status
    Aug-15 12:43:09 PM CasaTunes ERROR System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in :0 at System.Net.HttpWebRequest.GetResponse () [0x00016] in :0 at HSPI_CasaTunes.CasaAPI`1[T].Execute (System.String MethodType, System.String BaseURL, System.String Method, System.Collections.Generic.Dictionary`2[TKey,TValue] Parameters, System.String Payload) [0x000ce] in :0
    Aug-15 12:43:09 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/1/status
    Aug-15 12:43:06 PM CasaTunes DEBUG System.NullReferenceException: Object reference not set to an instance of an object at HSPI_CasaTunes.Zone+<>c__DisplayClass70_0. b__0 (HSPI_CasaTunes.RESTSource src) [0x00006] in :0 at System.Collections.Generic.List`1[T].Find (System.Predicate`1[T] match) [0x0000d] in <7b0d87324cab49bf96eac679025e77d1>:0 at HSPI_CasaTunes.Zone.PollZone (System.Object sender, System.Timers.ElapsedEventArgs e) [0x00232] in :0
    Aug-15 12:43:06 PM CasaTunes ERROR PollZones Object reference not set to an instance of an object
    Aug-15 12:43:06 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/105/status
    Aug-15 12:43:06 PM CasaTunes ERROR System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in :0 at System.Net.HttpWebRequest.GetResponse () [0x00016] in :0 at HSPI_CasaTunes.CasaAPI`1[T].Execute (System.String MethodType, System.String BaseURL, System.String Method, System.Collections.Generic.Dictionary`2[TKey,TValue] Parameters, System.String Payload) [0x000ce] in :0
    Aug-15 12:42:58 PM CasaTunes DEBUG System.NullReferenceException: Object reference not set to an instance of an object at HSPI_CasaTunes.Zone+<>c__DisplayClass70_0. b__0 (HSPI_CasaTunes.RESTSource src) [0x00006] in :0 at System.Collections.Generic.List`1[T].Find (System.Predicate`1[T] match) [0x0000d] in <7b0d87324cab49bf96eac679025e77d1>:0 at HSPI_CasaTunes.Zone.PollZone (System.Object sender, System.Timers.ElapsedEventArgs e) [0x00232] in :0
    Aug-15 12:42:58 PM CasaTunes ERROR PollZones Object reference not set to an instance of an object
    Aug-15 12:42:58 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/4/status
    Aug-15 12:42:58 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/1002/status
    Aug-15 12:42:58 PM CasaTunes ERROR System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in :0 at System.Net.HttpWebRequest.GetResponse () [0x00016] in :0 at HSPI_CasaTunes.CasaAPI`1[T].Execute (System.String MethodType, System.String BaseURL, System.String Method, System.Collections.Generic.Dictionary`2[TKey,TValue] Parameters, System.String Payload) [0x000ce] in :0
    Aug-15 12:42:57 PM CasaTunes DEBUG System.NullReferenceException: Object reference not set to an instance of an object at HSPI_CasaTunes.Zone+<>c__DisplayClass70_0. b__0 (HSPI_CasaTunes.RESTSource src) [0x00006] in :0 at System.Collections.Generic.List`1[T].Find (System.Predicate`1[T] match) [0x0000d] in <7b0d87324cab49bf96eac679025e77d1>:0 at HSPI_CasaTunes.Zone.PollZone (System.Object sender, System.Timers.ElapsedEventArgs e) [0x00232] in :0
    Aug-15 12:42:57 PM CasaTunes ERROR PollZones Object reference not set to an instance of an object
    Aug-15 12:42:57 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/0/status
    Aug-15 12:42:57 PM CasaTunes ERROR System.Net.WebException: The operation has timed out. at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in :0 at System.Net.HttpWebRequest.GetResponse () [0x00016] in :0 at HSPI_CasaTunes.CasaAPI`1[T].Execute (System.String MethodType, System.String BaseURL, System.String Method, System.Collections.Generic.Dictionary`2[TKey,TValue] Parameters, System.String Payload) [0x000ce] in :0
    Aug-15 12:42:57 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/2/status
    Aug-15 12:42:57 PM CasaTunes ERROR URL=http://10.1.80.11:8735/api/v1/zones/5/status
    Aug-15 12:42:51 PM CasaTunes DEBUG -->GET http://10.1.80.11:8735/api/v1/sources
    Aug-15 12:42:49 PM CasaTunes DEBUG -->GET http://10.1.80.11:8735/api/v1/zones/3/status
    Aug-15 12:42:49 PM CasaTunes DEBUG -->GET http://10.1.80.11:8735/api/v1/zones/1/status
    Aug-15 12:42:46 PM CasaTunes DEBUG -->GET http://10.1.80.11:8735/api/v1/zones/105/status
    Aug-15 12:42:38 PM CasaTunes DEBUG -->GET http://10.1.80.11:8735/api/v1/zones/4/status
    Aug-15 12:42:38 PM CasaTunes DEBUG -->GET http://10.1.80.11:8735/api/v1/zones/1002/status
    If you restart the plugin, do you see those errors immediately after the restart, or do they only show up after some time?
      Thanks spud
      I restarted the plugin and I did not see the errors immediately. Things appear to be working fine right now.
      Does this point you in the direction of the issue?
        Originally posted by JohnGalt View Post
        Thanks spud
        Yes I have an idea
        Please install and test version 3.0.0.12 available in the beta section
          Great!
          Thanks. I installed the beta version and hopefully will not have issues.
          Is there a time period where if I don’t see issues I should be in the clear?
