announcement volume
  • announcement volume
    Hi,
    I'm trying to find a streamlined way to max out the volume before making announcements. I have events that I want to announce ("front door opened" for example) and I want to make sure that it's heard. Normal music playing volume is often for ambiance and at like 30%.
    Short of storing the current volume in a virtual device (easy trigger), then increasing volume to 100%, then playing announcement, and restoring volume from the virtual device to return to "normal", is there a better way ?
    edit I've just tested sending the announcement while my google mini was streaming off google music, and it didn't resume playing after
    thanks
    Simon
    You can change the volume of any Chromecast device. Change the volume to 100% before the announcement, then change it back later. See the attached screenshot.
Name:	Screenshot 2018-04-08 11.00.21.jpg
      [ATTACH]68023[/ATTACH]
      You can easily do it in Windows using Jon00 RCControl plugin or Android with Node-RED and MQTT =====> Lowering kodi's volume before the announcement.
      Eman.
      Crash.
        The issue here is that I don't know what the volume percentage is at before the announcement. The principle behind an announcement should use an alternate volume setting than what is actually being streamed/played. Like car system that has different volumes for the radio, GPS directions and Bluetooth phone.
          In Windows it's easily definable by using the apps volumes. I do it in Android using Kodi because Kodi has its own volume. I have not tested it on other app like say Spotify or otherwise.
          You set main volume high. When the announcements come they are on the main volume so what you control is the apps volumes.
          Eman
          Crash.
            I'm sending the announcements to a google mini device, windows volume wont apply here ..
              Originally posted by simon@qic.ca View Post
              Hi,
              Did you ever come up with a solution for this?
              Because I'm currently doing it the first way you suggested (volume value to virtual device, then restoring from virtual device value after the announcement) but it is somewhat cumbersome.
