v 3.0.0.16 doesn't work for me
  • v 3.0.0.16 doesn't work for me
    Hello,
    Chromecast plugin : i have a critical error and in the log it is said : "Warning I/O interface Chromecast is down, executable is not running, restarting ..."
    I'm on windows 10 pro 64, bonjour & framework.net installed.
    when do you get this error? immediatly after you enable the plugin?
    what do you have in the logs?
      yes i have it immediately after enable the plugin
      mars-22 17:16:37 Info Plugin Chromecast with instance: has disconnected
      mars-22 17:16:36 Z-Wave Device: Node 15 Zwave-cache Watts Set to 9 (9 Watts)
      mars-22 17:16:34 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.7 (8.7 Watts)
      mars-22 17:16:32 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.9 (8.9 Watts)
      mars-22 17:16:26 Z-Wave Device: Node 12 Salon Watts 4 Set to 0.1 (0.1 Watts)
      mars-22 17:16:25 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.6 (8.6 Watts)
      mars-22 17:16:25 Chromecast INFO Chromecast version 3.0.0.16
      mars-22 17:16:25 Info Plugin Chromecast has connected. IP:127.0.0.1:57121
      mars-22 17:16:24 Z-Wave Device: Node 11 Chambre Parents Ordinateur Set to 1.6 (1.6 Watts)
      mars-22 17:16:24 Warning I/O interface Chromecast is down, executable is not running, restarting ...
      mars-22 17:16:23 Z-Wave Device: Node 11 Chambre Parents TV Set to 0.3 (0.3 Watts)
      mars-22 17:16:23 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.5 (8.5 Watts)
      mars-22 17:16:21 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.9 (8.9 Watts)
      mars-22 17:16:19 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.6 (8.6 Watts)
      mars-22 17:16:17 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.7 (8.7 Watts)
      mars-22 17:16:15 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.6 (8.6 Watts)
      mars-22 17:16:13 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.5 (8.5 Watts)
      mars-22 17:16:09 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.6 (8.6 Watts)
      mars-22 17:16:05 Z-Wave Device: Node 15 Zwave-cache Watts Set to 8.5 (8.5 Watts)
        What version of .NET do you have installed?
        could you try to start the plugin from an admin command prompt like in the screenshot below, there may be more information printed there to help us troubleshoot the problem.
        thanks
            somehow the plugin is trying to use a dll specific to Linux (Mono.Zeroconf.Providers.AvahiDBus.dll) which should not be present on a windows system.
            How have you installed the plugin?
            Delete everything in Bin/Chromecast, make sure you don't have some Mono.Zeroconf.xxxx.dll in the HS3 application folder. Then reinstall the Chromecast plugin from the updater.
              Thank u
              Bravo Spud, you were right, there were Mono.Zeroconf.xxxx.dll in my HS3 directory. It works now.
              Just 2 other questions,
              Could you tell me if i'm right : it's not possible for the moment to cast youtube video by events ?
              i'm kinda lost with the MIME/TYPE settings in events, is it obligatory to put a value here and if it that's the case, in type, is it the extention of media files that i have to set?
                yes MIME/TYPE needs to be filled, but when you write the url, the plugin is supposed to try to autofill the MIME/Type by parsing the extension of the url file. If the autofill fails, just google your type of media file and MIME Type.
