WiFi devices disconnecting
    It looks like there are some with similar issues. I have 5 chrome cast devices. 2 wired and 3 wireless. There is never problem with wired devices.
    When click on connect (for disconnected devices) nothing is happening. I get error in log as shown below.
    Disable/enable plugin helped once. After that it would not make any difference. Rebooting one disconnected device and then disable/enable plug-in brought everything back online for now.
    What can I do to keep wi-fi device visible to Chromecast plug-in? They are all connected and working fine outside of the plug-in all the time.
    Thank you for your advice. Charles
    I am on windows 10 machine and HS3 Pro all latest versions. I got the plug-in yesterday.. Ughh.. Couple of minutes later two wi-fi devices disconnected again.. I can't connect them from device list.. Same error as above. Feeling frustrated. :-(
      Do you have Bonjour installed?
        Yes I do.
        Actually here is what I have noticed. One Wi-Fi device would stay connected two would get disconnected. One that would stay connected is using manually assigned IP and two others are using DHCP server. I have assigned IP manually to other two devices and so far they are staying connected. It is early to tell but it might have solved the problem. Maybe it will help others too in the future.
        It could be issue related to my network. Who knows. I am using GT-AC5300 router.
          Seems a bit like what I'm experiencing:
          https://forums.homeseer.com/forum/3r...my-chromecasts
          I might try static IP to see if that helps.
            Well, so far so good.. All devices are still connected.. It definitely helped some.
              Hi - I'm having a similar issue. Google Chromecast Audio against a Homeseer (HS3 Troller).
              Chromecast Audio (Wifi only) works ok when the homeseer is rebooted, and the connection is all enabled (incl. Online)
              TTS from Homeseer works ok, as well the posting (URL) of an audio wav file
              ID Name Type IP Address Enabled TTS Online Test
              dd41770746009319764624cc9c05f9c0 Chromecast Speaker Chromecast Audio 192.168.1.19 Y Y Y Test
              After a while, it disconnects (see logs) - Online tick box is no longer connected
              dd41770746009319764624cc9c05f9c0 Chromecast Speaker Chromecast Audio 192.168.1.19 Y Y Test
              See Logs.
              Feb-11 20:33:03 Z-Wave ApplicationCommandHandler from Network: F52BF89F Node: 5 HANDLING: COMMAND_CLASS_METER_V4 Frame(7)=2
              Feb-11 20:32:41 Chromecast INFO Disconnected from chromecast All Speakers
              Feb-11 20:32:41 Chromecast INFO Disconnecting from All Speakers https://192.168.1.19:42309/
              Feb-11 20:32:41 Chromecast INFO Disconnected from chromecast Chromecast Speaker
              Feb-11 20:32:41 Chromecast INFO Lost Service: Google-Cast-Group-3E71D548335746259267776E78F85435
              Feb-11 20:32:41 Chromecast INFO Disconnecting from Chromecast Speaker https://192.168.1.19:8009/
              Feb-11 20:32:41 Chromecast INFO Lost Service: Chromecast-Audio-dd41770746009319764624cc9c05f9c0
              Feb-11 20:32:39 Chromecast DEBUG RX: { "sourceId": "receiver-0", "destinationId": "sender-0", "namespace": "urn:x-cast:com.google.cast.tp.heartbeat", "payloadUtf8": "{"type":"PONG"}" }
              Feb-11 20:32:39 Chromecast DEBUG TX: { "sourceId": "sender-0", "destinationId": "receiver-0", "namespace": "urn:x-cast:com.google.cast.tp.heartbeat", "payloadUtf8": "{"type":"PING"}" }
              Any ideas?
