Fatal Exception error
    After updating from trial to paid version, began getting on a google target test
    RROR System.FormatException: Input string was not in a correct format. at System.Number.StringToNumber (System.String str, System.Globalization.NumberStyles options, System.Number+NumberBuffer& number, System.Globalization.NumberFormatInfo info, System.Boolean parseDecimal) <0x749e0400 + 0x00130> in :0 at System.Number.ParseInt64 (System.String value, System.Globalization.NumberStyles options, System.Globalization.NumberFormatInfo numfmt) <0x749df228 + 0x000fb> in :0 at System.Int64.Parse (System.String s, System.IFormatProvider provider) <0x749ab020 + 0x00027> in :0 at System.Convert.ToInt64 (System.String value) <0x7492cef0 + 0x00033> in :0 at HSPI_Chromecast.GTTSToken.CalculateToken (System.String text, System.String seed) <0x7131a750 + 0x0008b> in :0 at HSPI_Chromecast.ChromecastApp.SpeakIn (System.Int32 device, System.String text, System.Boolean wait, System.String host) <0x713197a8 + 0x0068f> in :0
    I fixed the problem in version 3.0.0.22 available in the Beta section of the updater.
    Note that the Google voice TTS feature is a hack that can break at anytime if google make changes. That is what happened here.
    Please test and let me know.
      Hi, I've just had the same error and problem. Performed the 3.0.0.22 update but to no avail. Will reboot and see how it goes.
        you need to install version 3.0.0.29 available in the beta section of the updater.
        read this thread: https://forums.homeseer.com/forum/me...o-longer-works
          Spud,
          Champion. Yes It just worked then. Well done and thank you...
