Control for Play and Pause, can we have one control to toggle Play/Pause?
    Here's my current setup (simplified for the sake of this particular request):
    Homeseer HS3
    Allonis myServer (formerly Mainlobby)
    Russound MCA-C5 multi-zone audio controller with MDK-C6 keypads around the house
    Chromecast Audio
    Spud's Chromecast Plugin (just purchased today)
    Spotify is my primary music source on my Chromecast Audio
    The Allonis myServer Russound driver listens for keypad presses on the physical keypads around the house. I'm able to send commands from myServer to Homeseer HS3 via another plugin. For example, when I press "Next" on my physical in-wall keypad, I can send "BLML2HS|HS-ControlDevice~151~Go To End" to Homeseer and it goes to the next track. This works perfect.. The issue here is that my keypad only has a single button for Play/Pause, but the Chromecast plugin has two separate controls for Play and Pause.
    Spud, could you give us a "PlayPause" control I can call which toggles play/pause?
    Thank you very much!
    Thanks for purchasing the Chromecast plugin!
    There is already several solution to toggle between 2 different controls: for example you could use a simple script in an event, or you could use the Toggle action from the EasyTrigger plugin. Can't you use one of these solutions?
