Chromecast Plugin Disconnecting
  • #16
    Originally posted by brett_cp View Post
    Wow, that was quick! In my few minutes of testing so far this does appear to be resolved. I've noticed that the plugin disconnects periodically so I made a quick event:
    IF ChromecastAudio2751 Root changes and becomes Disconnected
    Then
    Set Device ChromecastAudio2751 Root to Connect
    This appears to work well - are there any downsides I'm not aware of in doing this? Thanks!
    Well, if if the plugin disconnects it is either because
    (a) the TCP connection has been broken, so in this case the plugin will try to reconnect automatically after 30 seconds
    or
    (b) Bonjour/Avahi says to the plugin that the chromecast has disappeared, in this case a reconnection shouldn't be needed until the chromecast service is advertised again by Bonjour/Avahi.
    You can look at debug logs, why it is disconnecting.
    Theoretically an event to reconnect shouldn't be needed, if you want to keep it, I would at least make it like below this to let the auto reconnection do its job
    IF ChromecastAudio2751 Root has been Disconnected for exactly 2 minutes
    Then
    • #17
      I am still getting these disconnect errors in the AM. I am on 3.0.0.27.
      Oct-29 3:17:44 AM Chromecast INFO Connected to chromecast Master Bedroom speaker
      Oct-29 3:17:44 AM Chromecast INFO Connecting to Master Bedroom speaker/
      Oct-29 3:17:44 AM Chromecast INFO Found Service: Chromecast-Audio-577451f8c2ae831194c7c
      Oct-29 3:17:00 AM Chromecast INFO Disconnected from chromecast Master Bedroom speaker
      Oct-29 3:17:00 AM Chromecast INFO Disconnecting from Master Bedroom speaker/
      Oct-29 3:17:00 AM Chromecast INFO Lost Service: Chromecast-Audio-577451f8c2ae831194c7c
      Oct-29 2:35:55 AM Chromecast INFO Connected to chromecast Living Room speaker
      Oct-29 2:35:55 AM Chromecast INFO Connecting to Living Room speaker/
      Oct-29 2:35:51 AM Chromecast INFO Found Service: Chromecast-Audio-0f0535dad554365369db0
      Oct-29 2:35:06 AM Chromecast INFO Disconnected from chromecast Living Room speaker
      Oct-29 2:35:06 AM Chromecast INFO Disconnecting from Living Room speaker/
      Oct-29 2:35:06 AM Chromecast INFO Lost Service: Chromecast-Audio-0f0535dad554365369db0
      • #18
        The plugin disconnects because Bonjour says the service is lost (log line: Lost Service: Chromecast-Audio-0f0535dad554365369db0). This may occur for various reasons, but the service reappears again and the plugin reconnects within 1 minute, so I think everything is fine.
        • #19
          or
          Then
          Thank you - I'll keep an eye on it. My Chromcast Audio is connected via wired Ethernet and is active/playing music during most of the day (I work from home). Your plugin has allowed me to tie my Chromecast Audio into Allonis myServer, has been great so far!
          • #20
            Ok, thanks Spud. Great plug-in by the way.
