Hi,
I keep getting the following error on startup:
Bonjour is running (mDNSresponder v3.0.0.10 is running in task manager).
This only happens when the HS computer is rebooted. When you go to the plugin page the chromecast devices are listed and enabled but NOT online.
But, if I stop the Chromecast plugin and then restart it then the plugin works. And the devices appear online. It's almost as if Bonjour is slow to startup or something. My computer is setup to start HS after a 10 second delay following boot, to allow other dependent services to load first.
Any suggestions?
Marty.
v-25 1:32:01 PM | Chromecast | ERROR System.Exception: No Zeroconf providers could be found or initialized. Necessary daemon may not be running. at Mono.Zeroconf.Providers.ProviderFactory.GetProviders() at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider( ) at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () at Mono.Zeroconf.ServiceBrowser..ctor() at HSPI_Chromecast.ChromecastDiscoverer.Start() at HSPI_Chromecast.ChromecastApp.b__70_0() |
Any suggestions?
Marty.
