Broadcast Function
    Broadcast Function
    Spud,
    Picked up your plugin about a month ago, works pretty well overall, thanks for your hard work. I've been trying to keep on the development of the Broadcast function, hoping that we'll be able to take advantage of it at some point. Have you seen this Google Assistant Relay project?
    https://community.smartthings.com/t/...cations/136473
    ...v
    I just had a quick look at it, and it's based on the Google Assistant API, this plugin is based on the Google Cast API. Moreover it would need a Node.js server running somewhere. So it is a bit out of the scope of this plugin.
      The nice thing about calling this from the assistant API is I think broadcast pauses the audio playing and resumes it somehow after the broadcast. But yes, it's a very different scope.
      Looks like Google is doing a lot of work on it's SDK's here, so I suspect this will all get easier over time.
      mike
        Not fully understanding the technical implications and trusting spuds' judgment that it might be hard or even impossible to implement, I'll just like to add that having a function similar to the broadcast function would be sooo great. Just sending an announcement to the google mini and then resume whatever it was playing before it something I really miss...
        stefxx
          To get this to work you would need to run another server program, node.js server. Best would be on another box like a Raspberry Pi and then Spud would have to modify his code as well. You would then have a three-way solution that would have to be configured, supported and troubleshot as well. Node.js server, HS3 server, Spud's Chromecast plug-in.
            I believe that if one goes through the effort of getting the program running on node.js, you could probably send the Broadcast api calls directly to the program, wouldn't technically need Spud's plugin at all.
            Sent from my LGUS997 using Tapatalk
