TTS Current weather
  • TTS Current weather
    Removed
    you can use a replacement variable .
    First , go to http://YOUR_IP:PORT/setup
    then go to the ''custom'' tab, and select the '' Show Device Reference Number on Device Management Page (for developers)''.
    This will add the reference column to the hs device page.
    Next, depending if you temperature is a string or a value you will add this at this end of your tts message :
    String :
    $$DTR:(ref):
    Value :
    $$DVR:(ref):
    Remove the () and put the ref number of your device in like this $$DVR:812:
    So we got
    welcome home, the time is $$time, the current temperature is $$DVR:812: degrees outside
    In your example you need to add one ''$'' to ''$time'' so you got ''$$time'' ( this is when the text is spoken)
      Reference: pages 35-36 of the hs3 manual https://homeseer.com/support/homeseer/HS3/HS3Help.pdf
        ha didn't know that thanks !
