Cast webpage?
    #16
    Originally posted by dannieboiz View Post
    saw this feature added to the latest beta release. Tried to cast my blueiris http stream as a webpage and it works great. This will be a very useful feature and will for sure open doors that was not possible previously.
    FWIW I've been casting the camera stream in a similar fashion and it works just fine. However, I also have a speak even that's tied to it and it doesn't work too well
    IE: My event would trigger and the action would be "Speak" - Motion at the front door then cast the video feed. doesn't work. In either order it doesn't work. Is there a work around?
    Does a Speak action work when you try to run it alone?
    If not, please provide some debug logs.
      #17
      Speak client works fine on its own, I think it has to do with trying to have it speak and cast at the same time that cancel itself out.
        #18
        Set wait for Speech to Finish in your event.
        Peter
        http://ohh.pcgsm.nl
          #19
          Although it adds a delay on showing the camera, but it works. .. thanks
            #20
            Can you put the show camera event first?
              #21
              doesn't work in that order. The limitation is the Google Home. When the speak client runs, it display a Homeseer screen, therefore; trying to cast the camera feed while it speaks causes a conflict.
              I imagine if we can turn off the HS wallpaper when it speak it might work.
              Oh and the ding before the cast/speak is annoying
