I have several event notifications consisting of a .wav tone followed by a speak action. Of late I'm having consistent delays of ~120 seconds for the audio to play on my GH minis via the chromecast PI. (Sometimes the .wav plays immediately, but the TTS seems to always be delayed). I've confirmed that the events are firing properly, just the audio is delayed.
The problem seems to have started when I segmented my IoT devices--including the minis--to a separate vlan/subnet, and I'm hoping someone here can give me advice on troubleshooting. My HS server and z-net are on my trusted network (vlan1/192.168.0.xxx) and minis are on vlan107/192.168.107.xxx. Firewall rules allow established and related connections from vlan107 -> vlan1, and all other traffic is dropped. No restrictions from vlan 1 -> vlan107. Might I need to poke another hole for the minis to work properly? I have no understanding of how Bonjour works and whether my firewall may be causing a problem there. I also read elsewhere about an issue with the GH going to sleep although I doubt that's the issue as I've repeated the test within minutes with the same results--and they shouldn't have gone to sleep that quickly.
I've attached a debug log that I started just before manually running an event with the notification actions. I disabled the log just after the audio actually played--about 2 minutes later.
Any advice appreciated. Thanks.
-Wade
edit: On the past 4 tests, 3 times the .wav file played immediately and the TTS was delayed 2+ minutes. The other time both were delayed.
MESSAGE BOARD (copy/paste section below to message board posts)
Current Date/Time: 7/1/2019 9:13:25 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.534
System Uptime: 0 Days 4 Hours 21 Minutes 58 Seconds
IP Address: 192.168.0.16
Number of Devices: 683
Number of Events: 393
Available Threads: 400
HSTouch Enabled: True
Event Threads: 1
Event Trigger Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
In Virtual Machine: No MFG: dell inc.
Enabled Plug-Ins
2.0.59.0: BLBackup
3.0.25.0: BLLock
2.0.28.0: BLOccupied
2.0.66.0: BLOnkyo
3.1.3.33206: Blue-Iris
3.0.0.34: Chromecast
3.0.0.65: EasyTrigger
3.0.0.31: EnvisaLinkAdemco
3.0.0.8: MeiUnifi
1.2019.211.1740: MyQ
3.0.0.33: Nest
3.0.0.63: PHLocation2
1.0.0.7: Restart
3.0.7.0: SDJ-Health
0.0.0.5: Sure Petcare 3P
3.0.2.261: Z-Wave
-Wade
Event Threads: 1
Email Send Queue: 0
Enabled Plug-Ins
2.0.59.0: BLBackup
3.0.25.0: BLLock
2.0.66.0: BLOnkyo
3.0.0.8: MeiUnifi
3.0.0.33: Nest
1.0.0.7: Restart
3.0.7.0: SDJ-Health
3.0.2.261: Z-Wave
