Local api changing for Google home/Chromecast devices
    Hi spud,
    Are you aware of this upcoming change to gh and Chromecast devices regarding local control?
    https://gist.github.com/rithvikvibhu...8453e3be482c1f
    Originally posted by viroid
    That's probably what this is from....
    Sep-10 18:08:53 Chromecast ERROR System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it 172.217.7.174:443 at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at HSPI_Chromecast.GTTSToken.WebGet(String uri) at HSPI_Chromecast.GTTSToken.GetTokenKey() at HSPI_Chromecast.GTTSToken.CalculateToken(String text, String seed) at HSPI_Chromecast.ChromecastTarget.SpeakTextEventHandler(Objec t sender, SpeakTextEventArgs args)
    No I don't think this error has anything to do with the change described in the link from OP
    This error means the plugin cannot access https://translate.google.com/ which it needs if you use the google voice for text to speech.
    So make sure you don't have a firewall or something blocking access to this url, and that it is accessible from your HS machine.
