Originally posted by sbessel
View Post
Feature: Add option to delay TTS stream after connection
Originally posted by spud View Post
"administraor" is that a typo or does this directory really exists?
It was a cheap Amazon mini Linux box that was apparently hand setup by someone overseas... they fat fingered it
It really doesn't cause me any issues unless I actually try and type it out...
Once I really figured out it was wrong I was too far into the install to back out.
I consider it an extra layer of 'security'
It is strange as the path is correct on the first line and wrong right after.
Code:Dec 5 16:29:59 bessel-homeseer mono[18722]: PlayWavFile: /home/administraor/HomeSeer/Media/TriangleDinnerBell.wav Dec 5 16:29:59 bessel-homeseer mono[18722]: Dec-05 16:29:59 ERROR System.IO.DirectoryNotFoundException: Could not find a part of the path "/home/administraor/HomeSeer\Media/TriangleDinnerBell.wav".
Scott
Hi,
I tried .42 on my Windows 10 machine and it kept crashing and restarting. I had to revert back to .40. Before upgrading to .42 I backed up my entire "HomeSeer HS3" directory. I restored .40 by copying the entire backed up folder back into place.
I tried changing to Debug logging while .42 was crashing and restarting, but I cannot locate any Chromecast log files in my "broken" HomeSeer HS3 directory. Sorry I can't be of more help.HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
Plugins: BLLAN, BLOccupied, BLUSBUIRT, Chromecast, Harmony Hub, Insteon, Jon00 Homeseer/Echo Skill Helper, Harmony Hub, Jon00 DB Charting, MediaController, NetCAM, PHLocation2, Pushover 3P, weatherXML, Z-wave
Also having problems with .42.. PI crash loops, especially when it's used .. Logs attached.
Chromecast.zip
Originally posted by spud View Postsorry for the crash in .42, I fixed it in 3.0.0.43
I can't upload it to the updater because the dev portal is currently broken. If you want to try it please install manually from the files attached
Yes, thanks for the quick fix. I'm running .43 and it appears to be stable. My particular issue is still present, but maybe it should be a separate thread?
I'm calling:
hs.PlayWavFile("C:\Program Files (x86)\HomeSeer HS3\Media" & param, "", true)
hs.Speak(speakText, true)
...in a script file. I will usually hear the WAV file, but I will not hear the Speak text unless I specify hs.WaitSecs(2) between those two commands. Even then I will sometimes miss the Speak text. I believe this has something to do with the duration of the WAV file. However I thought the last parameter in hs.PlayWaveFile() meant the script would wait until completion. Maybe that only works with Speaker.exe?
All that said, at times I would hear only the TTS, and not the WAV file, though this was rare. Perhaps that was a symptom of the issue that you recently fixed.
Basically, I want to play a WAV file then immediately play TTS after it completes, with out an extended wait/delay between the two. Different WAV files could be played prior to the TTS so duration will vary. Is what I want to achieve possible?
Originally posted by mrceolla View PostYes, thanks for the quick fix. I'm running .43 and it appears to be stable. My particular issue is still present, but maybe it should be a separate thread?
I'm calling:
Thank you for the confirmation, spud. I suppose I could store the duration of each file in the script and use that to guess a wait time. However I'd expect the time between HS sending the command and hearing the WAV file play could vary slightly each time making it difficult to eliminate any gap between the two.
Do you think the plugin will ever honor the Wait parameter? I could see it being difficult if not impossible to implement.HS4, Insteon, Z-wave, USB-UIRT, Harmony Hubs, Google Hub/Chromecasts/Speakers, Foscam & Amcrest cameras, EZVIZ DB1 doorbell
