Change Google TTS voice?
    I am testing using Google Home Mini's as announcement devices and would like an option to use a different Google TTS voice.
    In the Google home app I can select a lot of different male or female voices, most named by a color. Yet these settings are different that the plugin that seems to default to the standard female voice.
    I have searched and come up with nothing. I do not want to use HomeSeer voices as I am using a HomeTroller.
    thanks,
    Scott
    The way the plugin use Google voice is kind of a hack, it actually uses the TTS engine from the google translate page, in which you can't select the voice.
    So no it's not possible.
      So you are saying it is possible with HS4
      Thanks for the response, I can stop searching for a solution now.
      Scott
