Getting error "File does not exist"
    While I have been a HomeSeer user for the past 10 years. This is only my second post to the forums. I figured it was finally time to start looking at integrating my HS3 set-up with a few of my Chromecast devices. Having great experiences with a few of Spud's other plugins, I decided to try Chromecast.
    The Install went fine (HS3 Linux setup). I, however, got the warning message "File does not exist: /home/pi/HomeSeer/html/Wave/chromecast20191113102255216.wav" when sending a test message to one of the Chromcast devices. The test message was not played.
    I'm not sure what could be causing the warning. Could it possibly be permissions related?
    From the config page, try to set the voice to google instead of System
    When it is set to system, the plugin tries to use the same TTS system engine as the standard HS speaker client, but on Linux it can be tricky to set this up correclty.
      Thanks. I'll give it a try.
