4.0.9.0 Plugin crashing and restarting constantly
    Just updated to HS4 and trying the Chromecast plugin for the first time on Linux. What I am seeing is the plugin will start, I'll see the connecting message, then it will die and restart again. I turned on debugging, while I see it having an exception, I don't see what the issues is:
    I/O interface Chromecast is down, executable is not running, restarting ...
    4/18/2020 4:53:56 PM
    HomeSeer
    Info
    Plugin Chromecast with ID: Chromecast and Instance:  has disconnected
    Chromecast
    Debug
    port = 8009
    Chromecast
    Debug
    ID = 192.168.0.190
    Chromecast
    Debug
    System.NullReferenceException: Object reference not set to an instance of an object
    Chromecast
    Debug
    IPs(count = 1):192.168.0.190
    Chromecast
    Debug
    Unhandled Exception Trapped
    Chromecast
    Info
    Connecting to Home group https://192.168.0.114:42092/
    Chromecast
    Debug
    I have a mix of Google Minis, Google Homes, and Google Home Hubs. Thanks!!
    Could you try to start the plugin from the command line instead of starting it from the web UI, to see if there is more information when it crashes.
    sudo mono HSPI_Chromecast.exe
    what version of mono are you running?
      Thank you for the quick reply!
      Connecting to HomeSeer...
      Connected to HomeSeer
      Waiting for initialization...
      2020/04/19 10:32:54.786 INFO Chromecast version 4.0.9.0
      2020/04/19 10:33:16.527 INFO Connecting to Kitchen Home https://192.168.0.111:8009/
      2020/04/19 10:33:16.648 INFO Connecting to Office TV https://192.168.0.120:8009/
      2020/04/19 10:33:16.712 INFO Connecting to Family Room Home https://192.168.0.114:8009/
          Native Crash Reporting
      Got a SIGSEGV while executing native code. This usually indicates
      a fatal error in the mono runtime or one of the native libraries
      used by your application.
          Native stacktrace:
           (No frames)
          Telemetry Dumper:
      Pkilling 0xb699b430 from 0xb01ff430
      Pkilling 0xb6f76400 from 0xb01ff430
      Pkilling 0xb2aff430 from 0xb01ff430
      Pkilling 0xafbff430 from 0xb01ff430
      Pkilling 0xb04ff430 from 0xb01ff430
      Pkilling 0xb4276430 from 0xb01ff430
      Pkilling 0xb0dff430 from 0xb01ff430
      Pkilling 0xb30ff430 from 0xb01ff430
      Pkilling 0xb39ff430 from 0xb01ff430
      Pkilling 0xaf8ff430 from 0xb01ff430
      Pkilling 0xb2dff430 from 0xb01ff430
      Pkilling 0xb36ff430 from 0xb01ff430
      Pkilling 0xafeff430 from 0xb01ff430
      Pkilling 0xb07ff430 from 0xb01ff430
      Could not exec mono-hang-watchdog, expected on path '/etc/../bin/mono-hang-watchdog' (errno 2)
      Entering thread summarizer pause from 0xb01ff430
      Finished thread summarizer pause from 0xb01ff430.
      2020/04/19 10:33:16.944 INFO Connecting to Office display https://192.168.0.180:8009/
      Waiting for dumping threads to resume
      2020/04/19 10:33:16.981 INFO Connecting to Kid's Room Speaker https://192.168.0.199:8009/
      2020/04/19 10:33:17.039 INFO Connecting to Master Bedroom TV https://192.168.0.103:8009/
      2020/04/19 10:33:17.084 INFO Connecting to Master Bedroom display https://192.168.0.125:8009/
      2020/04/19 10:33:17.123 INFO Connecting to Home group https://192.168.0.114:42092/
      * Assertion at mini-generic-sharing.c:899, condition `oti' not met
      Mono JIT compiler version 6.8.0.105 (tarball Tue Feb  4 21:35:49 UTC 2020)
          TLS:           __thread
          SIGSEGV:       normal
          Notifications: epoll
          Architecture:  armel,vfp+hard
          Disabled:      none
          Misc:          softdebug
          Interpreter:   yes
          LLVM:          yes(610)
          Suspend:       preemptive
          GC:            sgen (concurrent by default)
        I should also note I just noticed there's a gen 2 Mini that didn't show up in that list either.
