Permanently Loosing Functionality
    I've been having more and more problems with the PI, so I decided to start clean. That has led to the following problem.
    1) The Plug-In is not adding ANY CCA's groups. I see them in the log file though.
    NOTE: The CCA's are on the 2G Radio on a VLAN (Unifi). Before this started (I was thinking was my problem) I had both radios combined on the IoT Wifi network. I separated them and added the CCA's to the 2G SSID.
    I can access the CCA Groups in both Google Home and Google Play Music.
    I've attached the log files.
    Chromecast.zip
    RJ_Make On YouTube
    Very strange. It appears I can use the device and force a connection but it the PI config. never updates. (it's like there are not syncing)
    RJ_Make On YouTube
      Losing.
      Curious, what's CCA stand for?
        Originally posted by Demusman View Post
        Losing.
        chromecast audio
          Losing.
          Yep, could not figure out a way to change the title.
          RJ_Make On YouTube
            spud any idea what could be causing this?
            Sent from my LM-G820 using Tapatalk
            RJ_Make On YouTube
              Looking through the logs I see the PI see's the groups but it doesn't do anything with it.
              Since it looks like this PI isn't going to be supported, is there anyway I can get a few past version to see if the problem exist in prev. versions?
              Click image for larger version  Name:	2020-06-27_17-20-34.png Views:	0 Size:	400.1 KB ID:	1397196
              RJ_Make On YouTube
