Everything works fine but when starting up HS3 the startup log is showing an error. I don't know what it is about or how to solve this.Error:
ERROR Error while connecting speaker client: System.Exception: The host failed to connect. Timeout occured. 15000 bij HSCF.Communication.Scs.Client.Tcp.TcpHelper.ConnectToServer( EndPoint endPoint, Int32 timeoutMs) bij HSCF.Communication.Scs.Client.Tcp.ScsTcpClient.CreateCommuni cationChannel() bij HSCF.Communication.Scs.Client.ScsClientBase.Connect() bij HSCF.Communication.ScsServices.Client.ScsServiceClient`1.Con nect() bij HSPI_Chromecast.SpeakerClient.Connect(String username, String password)
Connection status in the plugin are oke, enabled and online
How can I solve this?
