My TTS has stopped working, not exactly sure when, logs are full of errors.
Jan-13 16:21:07 Chromecast ERROR System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond [xxxx:xxxx:xxxx:829::200e]:443 at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at HSPI_Chromecast.GTTSToken.WebGet(String uri) at HSPI_Chromecast.GTTSToken.GetTokenKey() at HSPI_Chromecast.GTTSToken.CalculateToken(String text, String seed) at HSPI_Chromecast.ChromecastTarget.SpeakTextEventHandler(Objec t sender, SpeakTextEventArgs args)
Jan-13 16:20:57 Warning Plugin Chromecast is not responding but it is still running, not restarting yet.
Jan-13 16:20:26 Warning Plugin Chromecast is not responding but it is still running, not restarting yet.
Jan-13 16:20:25 Chromecast ERROR System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond [xxxx:xxxx:xxxx:829::200e]:443 at System.Net.Sockets.Socket.DoConnect(EndPoint endPointSnapshot, SocketAddress socketAddress) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.GetResponse() at HSPI_Chromecast.GTTSToken.WebGet(String uri) at HSPI_Chromecast.GTTSToken.GetTokenKey() at HSPI_Chromecast.GTTSToken.CalculateToken(String text, String seed) at HSPI_Chromecast.ChromecastTarget.SpeakTextEventHandler(Objec t sender, SpeakTextEventArgs args)
Jan-13 16:20:19 Error Posting back to plugin web page chromecastconfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
Jan-13 16:20:13 Error Posting back to plugin web page chromecastconfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
Jan-13 16:15:19 TTS Speak ():This is a test of the emergency broadcast system
Jan-13 16:15:19 Event Event Trigger "! Testing !!! Testing - HS Speak"
Jan-13 16:15:19 Event Event ! Testing !!! Testing - HS Speak triggered by the event page 'Run' button.
Based on another "TTS not working" thread, I updated to the lastest beta
Jan-13 16:29:17 Chromecast ERROR System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond [xxxx:xxxx:xxxx:829::200e]:443 at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult) at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context) at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(I AsyncResult ar) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSucce ss(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess AndDebuggerNotification(Task task) at HSPI_Chromecast.GoogleTts.LoggingHandler.d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at HSPI_Chromecast.GoogleTts.SpeakToFile(String text, String voice, String filePath) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: An error occurred while sending the request. ---> System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond [xxxx:xxxx:xxxx:829::200e]:443 at System.Net.Sockets.Socket.InternalEndConnect(IAsyncResult asyncResult) at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult) at System.Net.ServicePoint.ConnectSocketInternal(Boolean connectFailure, Socket s4, Socket s6, Socket& socket, IPAddress& address, ConnectSocketState state, IAsyncResult asyncResult, Exception& exception) --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetRequestStream(IAsyncResult asyncResult, TransportContext& context) at System.Net.Http.HttpClientHandler.GetRequestStreamCallback(I AsyncResult ar) --- End of inner exception stack trace --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSucce ss(Task task) at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccess AndDebuggerNotification(Task task) at HSPI_Chromecast.GoogleTts.LoggingHandler.d__3.MoveNext()<---
Jan-13 16:29:14 Warning Plugin Chromecast is not responding but it is still running, not restarting yet.
Jan-13 16:29:04 Error Posting back to plugin web page chromecastconfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
Jan-13 16:28:27 Speaker Speaker host added, Name: Chromecast Instance: MasterBedroom Chromecast IP address: 127.0.0.1
Jan-13 16:28:26 Speaker Speaker host added, Name: Chromecast Instance: Office speaker IP address: 127.0.0.1
Jan-13 16:28:26 Speaker Speaker host added, Name: Chromecast Instance: Bedroom 2 speaker IP address: 127.0.0.1
Jan-13 16:28:26 Speaker Speaker host added, Name: Chromecast Instance: Kitchen speaker IP address: 127.0.0.1
Jan-13 16:28:26 Speaker Speaker host added, Name: Chromecast Instance: MasterBedroom Speaker IP address: 127.0.0.1
Jan-13 16:28:26 Speaker Speaker host added, Name: Chromecast Instance: LivingRoom Chromecast IP address: 127.0.0.1
Jan-13 16:28:26 Speaker Speaker host added, Name: Chromecast Instance: Bathroom speaker IP address: 127.0.0.1
Jan-13 16:28:14 Starting Plug-In Plugin Chromecast started successfully in 567 milliseconds
Jan-13 16:28:14 Starting Plug-In Initializing plugin Chromecast ...
Jan-13 16:28:13 Starting Plug-In Chromecast loaded in 15020 milliseconds
Jan-13 16:27:59 Info Plugin Chromecast has connected. IP:127.0.0.1:60516
Jan-13 16:27:58 Warning I/O interface Chromecast is down, executable is not running, restarting ...
Jan-13 16:27:40 Warning In InitSingleIOPlugin: Object reference not set to an instance of an object.
Jan-13 16:27:40 Updater Re-initializing plugin after update.
Jan-13 16:27:37 Updater Install/Update of package Chromecast was successful.
Jan-13 16:27:37 Updater Extraction Complete.
Jan-13 16:27:37 Updater Extracting files from zip file: images.zip
Jan-13 16:27:37 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Config\\Chromecast.ini
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\Zeroconf.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\System.ValueTuple.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\System.Threading.Tasks.Extensions.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\System.Runtime.CompilerServices.Unsafe.dl l
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\System.Reactive.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\Sockets.Plugin.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\Sockets.Plugin.Abstractions.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\SharpCaster.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\Newtonsoft.Json.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\Chromecast\Google.Protobuf.dll
Jan-13 16:27:36 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_Chromecast.exe.config
Jan-13 16:27:35 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_Chromecast.exe
Jan-13 16:27:35 Updater Installing package Chromecast
Jan-13 16:27:35 Updater Update HSPI_Chromecast.exe downloaded successfully
Jan-13 16:27:35 ASR Speaker Client speech recognition stopped
Jan-13 16:27:35 Speaker Speaker host disconnected, Name: CHROMECAST IP address: 127.0.0.1
Jan-13 16:27:35 Updater Downloading update: Chromecast
Jan-13 16:27:35 Warning Problem shutting down plugin Msg-B:Chromecast
Jan-13 16:27:15 Info Plugin Chromecast with instance: has disconnected
Jan-13 16:27:15 Updater Plugin is loaded, unloading before updating.
Jan-13 16:27:15 Updater Starting download of updates
But that just yields a different result.
chromecast.ini
[SPEAK_PROXY]
forward_to_hs=True
voice_type=Google
voice_language=en-us
voice_speed=0.7
[CHROMECASTS]
7f041090830e2ff85998381479d01d90###ipaddress=192.168.26.206
7f041090830e2ff85998381479d01d90###port=8009
7f041090830e2ff85998381479d01d90###name=Bedroom 1 speaker
7f041090830e2ff85998381479d01d90###type=Google Home Mini
7f041090830e2ff85998381479d01d90###enabled=True
7f041090830e2ff85998381479d01d90###tts=True
9a5aac48ed36eb112633eba62c902225###ipaddress=192.168.26.51
9a5aac48ed36eb112633eba62c902225###port=8009
9a5aac48ed36eb112633eba62c902225###name=Bedroom 2 speaker
9a5aac48ed36eb112633eba62c902225###type=Google Home Mini
9a5aac48ed36eb112633eba62c902225###enabled=True
9a5aac48ed36eb112633eba62c902225###tts=True
c6908e6ec765533e0e7cc605c883168c###ipaddress=192.168.26.149
c6908e6ec765533e0e7cc605c883168c###port=8009
c6908e6ec765533e0e7cc605c883168c###name=Kitchen speaker
c6908e6ec765533e0e7cc605c883168c###type=Google Home Mini
c6908e6ec765533e0e7cc605c883168c###enabled=True
c6908e6ec765533e0e7cc605c883168c###tts=True
b4806fac5eadb731a2475827cc6243bd###ipaddress=192.168.26.175
b4806fac5eadb731a2475827cc6243bd###port=8009
b4806fac5eadb731a2475827cc6243bd###name=LivingRoom Speaker
b4806fac5eadb731a2475827cc6243bd###type=Google Home Mini
b4806fac5eadb731a2475827cc6243bd###enabled=True
b4806fac5eadb731a2475827cc6243bd###tts=True
e9a9a07b720bc81436ca2ca79e2d3cde###ipaddress=192.168.26.191
e9a9a07b720bc81436ca2ca79e2d3cde###port=8009
e9a9a07b720bc81436ca2ca79e2d3cde###name=MasterBedroom Chromecast
e9a9a07b720bc81436ca2ca79e2d3cde###type=Chromecast
e9a9a07b720bc81436ca2ca79e2d3cde###enabled=True
e9a9a07b720bc81436ca2ca79e2d3cde###tts=False
9fe5f4a98a4763322f6f38f85ad5f989###ipaddress=192.168.26.229
9fe5f4a98a4763322f6f38f85ad5f989###port=8009
9fe5f4a98a4763322f6f38f85ad5f989###name=Office speaker
9fe5f4a98a4763322f6f38f85ad5f989###type=Google Home Mini
9fe5f4a98a4763322f6f38f85ad5f989###enabled=True
9fe5f4a98a4763322f6f38f85ad5f989###tts=True
9863f135340306324c020a5cf58776f0###ipaddress=192.168.26.239
9863f135340306324c020a5cf58776f0###port=8009
9863f135340306324c020a5cf58776f0###name=Bathroom speaker
9863f135340306324c020a5cf58776f0###type=Google Home Mini
9863f135340306324c020a5cf58776f0###enabled=True
9863f135340306324c020a5cf58776f0###tts=True
7fa5bae85f8603328589c1a5a9cd3370###ipaddress=192.168.26.188
7fa5bae85f8603328589c1a5a9cd3370###port=8009
7fa5bae85f8603328589c1a5a9cd3370###name=LivingRoom Chromecast
7fa5bae85f8603328589c1a5a9cd3370###type=Chromecast
7fa5bae85f8603328589c1a5a9cd3370###enabled=True
7fa5bae85f8603328589c1a5a9cd3370###tts=False
70568b74c1ffbe522d4655bac41a859e###ipaddress=192.168.26.147
70568b74c1ffbe522d4655bac41a859e###port=8009
70568b74c1ffbe522d4655bac41a859e###name=MasterBedroom Speaker
70568b74c1ffbe522d4655bac41a859e###type=Google Home Mini
70568b74c1ffbe522d4655bac41a859e###enabled=True
70568b74c1ffbe522d4655bac41a859e###tts=True
[VOLUME]
step=10
[GENERAL]
log_level=Warning
I'm noticing that within the chromecast.ini file, the devices are referenced by their IPv4 address, but the error messages in HomeSeer3 contain the IPv6 address for the device.
A while back I switched from manually defining the devices in the .ini file to discovery-mode, hoping that I could pull in the Speaker Groups, but I don't think the plugin supports that. Anyhow, it was working, and I was bouncing between HS3 and HS4 installs, so I figured auto-discovery was better.
Thoughts?
...v
chromecast.ini
[SPEAK_PROXY]
forward_to_hs=True
voice_type=Google
voice_speed=0.7
[CHROMECASTS]
[VOLUME]
step=10
[GENERAL]
log_level=Warning
Thoughts?
...v
