Hi spud,
Sorry for the wrong titel. That was my first problem but I already solved that.
I already use your iTunesDaap and Airplayspeak plugins for many years with great pleasure. Now I would like to integrate events that run a Google home command/device with your chromecast plugin. Although I spent many hours trying, I can not get it to work.
I would like to set an device to on/off. So I use Hey google, set ... to ON. This works fine when manually spoken directly to google assistant. But unfortunately not through the plugin with a TTS message. Google home is running on a tablet that is always on.
The problem is, that Google Home does not respond to a TTS message. A TTS message run by a HS event is spoken by the chromecast as it should. It is loud and clear in all the preferred languages. It shows up at the chromecast screen, I see in Google Home that there is a file made while speaking. Or at least it looks like.
Tried changing the HS IP binding. Add firewall rules for hspi_chromecast.exe. Tried without firewall. Different speech engines. But no luck.
Running the latest beta plugin. And I use several scripts that read an internet site, for example for an API. So the internet connection within HS is working as it should. https://translate.google.com/ is reachable from the HS machine, when I try this in edge. I also pinged the local address which is equal to the address in the debug file, just to be shure.
Attached a debug file log. Maybe that can give you a clue what is wrong? Do I miss something?
Many thanks in advance!
