Contacting HomeSeer This Week
See more
See less
Issues with Clients
  • Issues with Clients
    Just bought this plugin. Impressive.
    I have four clients, which I can change channels but can not turn on or off.
    The main Genie does respond to off and on.
    Any suggestions>
    Don
    It's a known problem, On/Off doesn't work for Genie clients, unfortunately the problem is not on the plugin side and I never found any explanation or workaround for this issue.
      Thanks.
      Don
        So, I'm trying to Power On the Genie itself with the command
        PHP Code:
        hs.PluginFunction("DirecTV""MEDIA""SendRemoteKeyCmd", New Object() {"Power On"})
        Which isn't working. Is my syntax incorrect? I can control the power from the DirecTV Remote Control.
        Don
          PHP Code:
          sorry, I should have mentioned that in the user guide, the possible values for the key parameter are:
          "power", "poweron", "poweroff", "format", "pause", "rew", "replay", "stop", "advance", "ffwd", "record", "play", "guide", "active", "list", "exit", "back", "menu", "info", "up", "down", "left", "right", "select", "red", "green", "yellow", "blue", "chanup", "chandown", "prev", "0", "1", "2", "3", "4", "5", "6", "7", "8"
          , "9", "dash", "enter"
            Ah, I see.
            Don
