Odd error
  • Odd error
    Noticed this in the log today.
    Nov-05 1:42:51 PM DirecTV DEBUG Stack: at Newtonsoft.Json.Utilities.ConvertUtils.Int32Parse(Char[] chars, Int32 start, Int32 length) at Newtonsoft.Json.JsonTextReader.ParseNumber() at Newtonsoft.Json.JsonTextReader.ParseValue() at Newtonsoft.Json.JsonTextReader.ReadInternal() at Newtonsoft.Json.JsonReader.ReadAsInt32Internal() at Newtonsoft.Json.JsonTextReader.ReadAsInt32() at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.R eadForType(JsonReader reader, JsonContract contract, Boolean hasConverter) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.P opulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.C reateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue) at Newtonsoft.Json.Serialization.JsonSerializerInternalReader.D eserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent) at Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReade r reader, Type objectType) at Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings) at Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value) at HSPI_DIRECTV.DirecTVApp.SendGetTunedCmd()
    Nov-05 1:42:51 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:42:51 PM DirecTV DEBUG { "callsign": "MCSR", "duration": 4294967295, "isOffAir": false, "isPclocked": 3, "isPpv": false, "isRecording": false, "isVod": false, "major": 849, "minor": 65535, "music": { "by": "Don Henley / Bruce Hornsby", "cd": "The End Of The Innocenc...(1989)", "title": "The End Of The Innocence" }, "offset": 50015, "programId": "369150", "rating": "No Rating", "startTime": 1572958857, "stationId": 2204323, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/tv/getTuned?clientAddr=0036764DC094" }, "title": "To Be Announced" }
    Nov-05 1:42:50 PM DirecTV INFO CMD SENT: http://192.168.42.105:8080/tv/getTun...r=0036764DC094
    Nov-05 1:42:50 PM DirecTV DEBUG { "mode": 0, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=0036764DC094" } }
    Nov-05 1:42:50 PM DirecTV INFO CMD SENT: http://192.168.42.105:8080/info/mode...r=0036764DC094
    Nov-05 1:42:50 PM DirecTV DEBUG { "locations": [ { "clientAddr": "0", "locationName": "DON OFFICE", "tunerBond": true }, { "clientAddr": "0036764DC094", "locationName": "MEDIASERVER" } ], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
    Nov-05 1:42:50 PM DirecTV INFO CMD SENT: http://192.168.42.105:8080/info/getLocations?
    Nov-05 1:40:00 PM Z-Wave Device: Shop Shop RTC Temperature Set to 77 (F)
    Nov-05 1:38:56 PM Info Plugin DirecTV with instance: DONOFFICE has disconnected
    Nov-05 1:38:56 PM Plug-In Shutting down Plug-In: DirecTV
    Nov-05 1:38:29 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:38:25 PM Info Plugin DirecTV with instance: GREATROOM has disconnected
    Nov-05 1:38:25 PM Plug-In Shutting down Plug-In: DirecTV
    Nov-05 1:37:50 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:36:28 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:34:27 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:32:49 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:32:26 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Nov-05 1:30:25 PM DirecTV ERROR Arithmetic operation resulted in an overflow.
    Don
    the reported duration value in your log is greater than the max value of the integer type I was using in the plugin.
    I fixed it in version 3.0.0.20, available in the beta section of the updater
      Thank you.
      Don
