Support for Genie Clients?
  • #31
    I just tried it and verified that entering the main Genies IP fixes the issue and gives you the drop down list for the RVU internal client.
    • #32
      yep... maybe Spud will change the wording..
      Ubuntu 16.10 (64) | HSPro 3.0.0.297 | Z-Wave 3.0.1.124 | Server .94 | BL BackUp | BLOccupied | BLLock | Media Controller | Jowi HUE | HSTouch | DSC-Envisalink | I-Tunes DAAP | DirecTV | Restart | Honeywell WiFi | Weather XML | RFX Com | + Android .117 : IOS 8
      • #33
        It seems I have started having problems with the genie and clients since the update to 3.0.0.67 HS Touch Server, 3.0.0.177 HS3, and 3.0.0.30 HS3 Designer.
        I updated to the latest yesterday and the Genie is allowing for the "Genie" or "A" drop down when I put in the IP address but the client is not giving that option.
        I just tried to put the plugin to "debug" and now when I click on the Config tab of an instance, I get this
        May-24 5:28:23 PM	 	Error	Getting plugin GenPage: The method or operation is not implemented.
        The different instances seem to be disappearing form the plugin drop downs when trying to get to the Config and Remote...
        It seems I have already tried removing the instances, then trying to add them again but no luck...
        Any suggestions?
        Forgot to mention, I am on version 14 of plugin.
        • #34
          Any suggestions?
          when you configure an instance for a Genie client, you need to make sure your Genie client is turned on, then in the config page you need to fill in the IP address of the Genie box (not the client), and then select the client name from the dropdown.
          • #35
            Yes, I made sure all clients were on with the genie when creating the instances...and at first the "A" is with "Genie" and I select it for the client instance. Then a couple of minutes later, the "A" is not available and can't control the client but can still control the genie through the interface.
            • #36
              Not sure if you like this way for the log or if you prefer notebook...
              May-24 5:50:07 PM	 	DirecTV	DEBUG { "callsign": "DIYHD", "date": "20141104", "duration": 3600, "episodeTitle": "Transforming a Shipping Container Into a Portable Barnwood Cabin", "isOffAir": false, "isPclocked": 3, "isPpv": false, "isRecording": false, "isVod": false, "major": 230, "minor": 65535, "offset": 3000, "programId": "15502787", "rating": "TV-G", "startTime": 1432504800, "stationId": 9164637, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/tv/getTuned?clientAddr=80F50364F73A" }, "title": "Barnwood Builders" }
              May-24 5:50:07 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/tv/getTuned?clientAddr=80F50364F73A
              May-24 5:50:07 PM	 	DirecTV	DEBUG { "mode": 0, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=80F50364F73A" } }
              May-24 5:50:06 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=80F50364F73A
              May-24 5:50:06 PM	 	DirecTV	DEBUG { "locations": [ { "clientAddr": "0", "locationName": "GENIE" }, { "clientAddr": "80F50364F73A", "locationName": "A" } ], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:50:06 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:50:01 PM	 	DirecTV	DEBUG { "hold": "keyPress", "key": "poweroff", "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/remote/processKey?key=poweroff&clientAddr=80F50364F73A" } }
              May-24 5:50:01 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/remote/processKey?key=poweroff&clientAddr=80F50364F73A
              May-24 5:49:19 PM	 	DirecTV	DEBUG { "locations": [ { "clientAddr": "0", "locationName": "GENIE" }, { "clientAddr": "80F50364F73A", "locationName": "A" } ], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:49:19 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:49:17 PM	 	DirecTV	DEBUG { "locations": [ { "clientAddr": "0", "locationName": "GENIE" }, { "clientAddr": "80F50364F73A", "locationName": "A" } ], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:49:17 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:49:02 PM	 	DirecTV	DEBUG Stack: at HSPI_DIRECTV.DirecTVApp.SendGetModeCmd()
              May-24 5:49:02 PM	 	DirecTV	ERROR Object reference not set to an instance of an object.
              May-24 5:49:01 PM	 	DirecTV	DEBUG { "callsign": "DIYHD", "date": "20141104", "duration": 3600, "episodeTitle": "Transforming a Shipping Container Into a Portable Barnwood Cabin", "isOffAir": false, "isPclocked": 3, "isPpv": false, "isRecording": false, "isVod": false, "major": 230, "minor": 65535, "offset": 2934, "programId": "15502787", "rating": "TV-G", "startTime": 1432504800, "stationId": 9164637, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/tv/getTuned?clientAddr=80F50364F73A" }, "title": "Barnwood Builders" }
              May-24 5:49:01 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/tv/getTuned?clientAddr=80F50364F73A
              May-24 5:49:01 PM	 	DirecTV	DEBUG { "mode": 0, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=80F50364F73A" } }
              May-24 5:49:00 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=80F50364F73A
              May-24 5:49:00 PM	 	DirecTV	DEBUG { "locations": [ { "clientAddr": "0", "locationName": "GENIE" }, { "clientAddr": "80F50364F73A", "locationName": "A" } ], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:49:00 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:48:59 PM	 	DirecTV	DEBUG { "callsign": "DIYHD", "date": "20141104", "duration": 3600, "episodeTitle": "Transforming a Shipping Container Into a Portable Barnwood Cabin", "isOffAir": false, "isPclocked": 3, "isPpv": false, "isRecording": false, "isVod": false, "major": 230, "minor": 65535, "offset": 2933, "programId": "15502787", "rating": "TV-G", "startTime": 1432504800, "stationId": 9164637, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/tv/getTuned?clientAddr=0" }, "title": "Barnwood Builders" }
              May-24 5:48:59 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/tv/getTuned?clientAddr=0
              May-24 5:48:59 PM	 	DirecTV	DEBUG { "mode": 0, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=0" } }
              May-24 5:48:59 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=0
              May-24 5:44:01 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:44:00 PM	 	DirecTV	DEBUG { "locations": [{ "clientAddr": "0", "locationName": "GENIE" }], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:44:00 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:43:59 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:43:59 PM	 	DirecTV	DEBUG { "locations": [{ "clientAddr": "0", "locationName": "GENIE" }], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:43:59 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:43:57 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:41:34 PM	 	DirecTV	DEBUG { "locations": [{ "clientAddr": "0", "locationName": "GENIE" }], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:41:34 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:40:50 PM	 	DirecTV	DEBUG { "mode": 1, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=0" } }
              May-24 5:40:50 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=0
              May-24 5:39:55 PM	 	DirecTV	DEBUG Stack: at HSPI_DIRECTV.DirecTVApp.SendGetModeCmd()
              May-24 5:39:55 PM	 	DirecTV	ERROR Object reference not set to an instance of an object.
              May-24 5:36:34 PM	 	DirecTV	DEBUG { "locations": [{ "clientAddr": "0", "locationName": "GENIE" }], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:36:34 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:35:50 PM	 	DirecTV	DEBUG { "mode": 1, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=0" } }
              May-24 5:35:50 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=0
              May-24 5:34:55 PM	 	DirecTV	DEBUG Stack: at HSPI_DIRECTV.DirecTVApp.SendGetModeCmd()
              May-24 5:34:55 PM	 	DirecTV	ERROR Object reference not set to an instance of an object.
              May-24 5:31:34 PM	 	DirecTV	DEBUG { "locations": [{ "clientAddr": "0", "locationName": "GENIE" }], "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/getLocations" } }
              May-24 5:31:34 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:30:50 PM	 	DirecTV	DEBUG { "mode": 1, "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/info/mode?clientAddr=0" } }
              May-24 5:30:50 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=0
              May-24 5:30:45 PM	 	DirecTV	DEBUG { "hold": "keyPress", "key": "poweroff", "status": { "code": 200, "commandResult": 0, "msg": "OK.", "query": "/remote/processKey?key=poweroff&clientAddr=0" } }
              May-24 5:30:44 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/remote/processKey?key=poweroff&clientAddr=0
              May-24 5:29:53 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:27:19 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:26:34 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:26:04 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/tv/getTuned?clientAddr=0
              May-24 5:26:04 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/mode?clientAddr=0
              May-24 5:25:59 PM	 	DirecTV	DEBUG Stack: at HSPI_DIRECTV.DirecTVApp.SendGetModeCmd()
              May-24 5:25:59 PM	 	DirecTV	ERROR Object reference not set to an instance of an object.
              May-24 5:21:34 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:21:29 PM	 	DirecTV	INFO WebException: ProtocolError The remote server returned an error: (400) Bad Request.
              May-24 5:21:29 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/remote/processKey?key=poweron&clientAddr=80F50364F73A
              May-24 5:21:09 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:21:07 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:21:04 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.68:8080/info/getLocations?
              May-24 5:21:03 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:20:58 PM	 	DirecTV	INFO DirecTV version 3.0.0.14
              May-24 5:19:23 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.89:8080/info/mode?clientAddr=0
              May-24 5:19:22 PM	 	DirecTV	INFO CMD SENT: http://192.168.1.69:8080/info/mode?clientAddr=0
              • #37
                It does appear to be controlling it, but I have been only trying to turn it off and for some reason it wont power off, but it will change channels and other controls.
                Are the Genie and Clients supposed to always be in the Power On state?
