How to sync DTV receivers
  • How to sync DTV receivers
    It is a common occurrence for us to leave the Man Cave and go to the Kitchen. Invariably, somebody doesn't want to miss out on what they were watching in the Man Cave. So.... I'm looking for a way to hit a button and sync the Kitchen channel with the Man Cave channel. I pretty sure a simple script would do it. Am I on the right track?
    Sub Main(ByVal parm as object)
    hs.PluginFunction("DirecTV", "Kitchen", "SendTuneChannelCmd", New Object() {hs.DeviceString(440)})
    End Sub
    hs.DeviceString(440) is the string containing the Man Cave channel number.
    Enabled Plug-Ins:
    yeah something like that should work, you may have to cast the device string to an integer
        hs.PluginFunction("DirecTV", "Kitchen", "SendTuneChannelCmd", New Object() {CType(hs.DeviceString(440),Integer)})
    End Sub
      That worked like a charm! Thank you VERY much.....
      Enabled Plug-Ins:
        Do you mind sharing what hardware you are using to relay these commands?
