Channel, call sign, rating and title not updating
  • Channel, call sign, rating and title not updating
    I've installed the plug-in to test interaction with my Genie and three clients. The plug-in installs and sees the clients without issue. Remote control works fine, but the channel, call sign, rating and title values are not updating properly. Any ideas?
    by default the plugin polls the clients once every 5 minutes to update the channel, title, etc.. This polling interval is configurable from the config page.
    If you change the channel or use the remote keys through HS3, the devices should be refreshed within 5 seconds
    if you still think there is a problem (devices are not updated after 5 minutes) then set the log level to debug from the config page and post the logs here
    thanks
