Errors in the log
  • Errors in the log
    Hi Spud,
    I seem to be getting these errors in the log for the DirecTV plugin.
    Jan-18 5:43:40 PM         DirecTV    INFO WebException: ConnectFailure Unable to connect to the remote server
     Jan-18 5:43:40 PM         DirecTV    ERROR Object reference not set to an instance of an object.
     Jan-18 5:43:19 PM         DirecTV    INFO CMD SENT: http://192.168.xxx.xxx:8080/info/mode?clientAddr=0
     Jan-18 5:38:19 PM         DirecTV    INFO WebException: ConnectFailure Unable to connect to the remote server
     Jan-18 5:38:19 PM         DirecTV   ERROR Object reference not set to an instance of an object.
    Any idea what is causing this?
    _______________________________________________
    HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
    Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
    Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
    Originally posted by jlrichar View Post
    Hi Spud,
    I don't know if this is the case, but I get the same errors when I disconnect the receiver from power. It will also give the same error if the IP connection is lost. Since mine are SWM units, that error will show up when the RF cable is disconnected.
    Randy Prade
    Aurora, CO
    Prades.net
      The plugin polls every DirecTV receiver every X minutes. The error means the plugin can't reach this receiver (receiver is not connected to power, the wrong IP is configured, etc...)
      I guess I could do a better job to trap this error, and do not log anything at error level, I'll try to do that.
