DirecTV upgrade to Genie does not discover all clients
  • DirecTV upgrade to Genie does not discover all clients
    DirecTV upgraded our equipment. We had been running a Genie HR34, an HR24 and 3 H25 boxes. Each unit had its own IP. The new system is a Genie HR54 and 4 genie minis. Each mini is a client without a tuner or IP. I disabled and deleted all instances of the plug-in, deleted the old config files and reinstalled the plug-in. I set the initial instance of the plug-in to the IP of the server. Then I added 4 more instances of the plug-in all with the same IP as the server. Each instance has a drop down with the server and the same two clients as choices. Two of the clients do not show up.
    I went through the same process twice, always with the same result.
    Ideas?
    Randy Prade
    Aurora, CO
    Prades.net
    make sure that all your clients are On then from a browser go to
    http://<ip_of_hr54>:<port>/info/getLocations
    and see if it returns more than 2 clients, if you only see 2 clients the problem is on DirecTV side, maybe there something new to configure?
      I'll try that and let you know. DirecTV limits to 4 clients being on at a time, so I will turn the two on that are not being found and the other two off.
      Randy Prade
      Aurora, CO
      Prades.net
        OK. I have the Genie "MEDIA" and 4 clients "LR", "MBR", "US" and DS. The plug-in detected MEDIA, MBR and LR. I turned MBR off. and turned DS and US on. MEDIA is also off. Here is what the URL returned:
          "locations": [
              "clientAddr": "0",
              "locationName": "MEDIA",
              "tunerBond": true
              "HEVC": true,
              "clientAddr": "D42C0FF71964",
              "locationName": "LR"
              "clientAddr": "08EB744E2015",
              "locationName": "US"
              "clientAddr": "08EB748999BB",
              "locationName": "DS"
          "status": {
            "code": 200,
            "commandResult": 0,
            "msg": "OK.",
            "query": "/info/getLocations"
        It reported all 4 that were on. Is there something I can do to force the plug-in to refresh since it only discovers the clients that are on?
        This screenshot shows only the original 3 that were discovered.
        Randy Prade
        Aurora, CO
        Prades.net
          This morning I deleted the "DS" and "US" plug-in instances. Then I deleted the config files for those two. I turned off all clients and turned on the US and DS Genie clients. I created two new instances of the plug-in and was able to select among "Media", "DS" and "US". I now have all 5 devices configured. When I tried a couple of days ago I has 4 clients on and among them were US and DS, but they didn't show up. I have no clue why it worked today, but problem is solved.
          Randy Prade
          Aurora, CO
          Prades.net
            I will add a button to be able to refresh the list of clients from the config page. (the only solution to do that currently is to restart the plug-in instance)
              in version 3.0.0.16 available here, I have added a refresh button next to the dropdown list of clients.
                Thanks. Mine discovered all of the clients as long as there were 2 or less on at a time. It always found the Genie, it was the clients that didn't always show up. Once added, the plug-in can control any client function, except for power off, on or toggle. The format button also doesn't work. This is on the clients, I have not tested the Genie. Three of the clients are Genie Minis and the third is the new 4K Genie Mini. The server is an HR-54 Genie 4K receiver.
                Randy Prade
                Aurora, CO
                Prades.net
                  I also just received the HR-54 upgrade w/ 3 ea 4K wired clients
                  I will try this week-end with the new plug-in
                  Previous I only saw the genie and the first client. my fault.. the others were not turned on..
                  Geary
                  Ubuntu 16.10 (64) | HSPro 3.0.0.297 | Z-Wave 3.0.1.124 | Server .94 | BL BackUp | BLOccupied | BLLock | Media Controller | Jowi HUE | HSTouch | DSC-Envisalink | I-Tunes DAAP | DirecTV | Restart | Honeywell WiFi | Weather XML | RFX Com | + Android .117 : IOS 8
