I have seen in other threads that this runtime error has been discussed before, however I am not able to figure out why this is happening:.
1. I use a newer version of XMLTV (5.45) to be able to download tv-grab_no, the one coming with hstv plugin did not work.
2. Event HSTV download completes ok. I only uses one source so I have removed 'multi ' in param to hstv.exe.
3. Event HSTV import does the job, imports channels using a long time, the progress can be followed in s1 status.But when the cleanup starts it gets run time error 2147217900(80040E14) Syntax error in date in querry.
I have tried every advice in the documentation and threads , to set the ODBC correctly. (and the Database HSTV is updated. (It does not matter if i use multi or not in parameter setting.)
Attaching my ini file.
Thanks for any help, to solve this issue.
