Unable to Record
  • Unable to Record
    Perhaps I just do now know how to set up an IR control page to record programs but I have not been successful in getting anything recorded. My control item setup follows:
    Control Item IR Setup
    Record Command Minutes To Pad : 0
    String to Pause IR output: ,,,
    How many characters should channel numbers be? 2 0's will be appended.
    Change Device - Select the Channel Change Device from the Infrared Devices or enter an IR Device in the textbox below.
    Change Channel Prepend IR Command
    Change Channel Device
    Change Channel Device : Tolshiba_VCR
    Change Channel Append IR Command
    Record Device - Select the Record Device from the Infrared Devices or enter an IR Device in the textbox below.
    Record Device : Toshiba_VCR
    Record Device
    Record Device Prepend IR Command
    Record Device Record Command : Record
    Record Device Append IR Command
    Use An Event To Stop Recording : Yes
    Record Device Prepend Stop Command
    Record Device Stop Command : Stop
    Record Device Append Stop Command
    Enable IR Time (h:mm am/pm) : 1:00 AM
    Disable IR Time (h:mm am/pm) : 1:00 AM
    All of the required IR commands for, say, record on channel 24 work if sent with hs.sendir command in a script-shown below
    Toshiba_VCR, 2,,,Toshiba_VCR, 4,,,Toshiba_VCR, Record,,,Toshiba_VCR,Stop
    I do not know what I am doing wrong in setting up the control with HSTV. Perhaps someone can point me in the right direction.
    Mark
    Were you successful in setting up change channels from the tv listing station icon button? I have not been and am also using the usbuirt.
    John
      I was looking through the code.
      If you set the logging to the highest level and then have a show that should send some IR, it should put an entry into the HS log.
      Look for something like this:
      Sending IR string: _________
      If someone can post the string so I can see what is wrong with it, I can adjust the code to output the correct string.
      Jeff Farmer
      HS 3, HSPhone
        Detailed Log
        Turned on detailed logging and pressed the HBO icon for channel 952
        10/20/2007 3:01:31 PM HSTV SELECT optionValue, optionName FROM userOptions WHERE optionName = 'userStartPage' AND userID = 'blott'
        10/20/2007 3:01:31 PM HSTV SELECT UserID FROM userOptions WHERE OptionName = 'pgprivtvadmin' AND OptionValue = '1'
        10/20/2007 3:01:31 PM HSTV SELECT OptionValue, OptionName FROM UserOptions WHERE UserID = 'blott' AND OptionName IN ('intShowNameNum','intUseNickName','intDispShowLength','intS howYear','intShowRepeat','strShowAudio','strShowSubtles','st rShowRating','strShowEPNum','strShowCat','intShowVideo','int ShowActor','intShowGuest','intShowHost','intShowDirector','i ntShowProducer','intChanSortOrder', 'intHoursWide','intJumpWhen','intRepeatHours','intShowCatLeg end','intShowWeekDay','intShowGrid','tuneItem','gridChanSort Order')
        10/20/2007 3:01:31 PM HSTV SELECT c.channelID, c.channelname, c.channelnickname FROM tvChannels c, userChannels u WHERE u.channelID = c.channelID AND u.userID = 'blott' AND u.IsSelected = 1 AND u.IsAllowed = 1 AND c.channelID IN (SELECT DISTINCT channelID FROM tvlistings) ORDER BY u.sortorder, c.channelname
        10/20/2007 3:01:31 PM HSTV SELECT t.starttime, t.endtime, c.channelNumber, u.SortOrder, c.channelName, u.userid, t.title, t.episode, t.description, t.category, t.episodenum, t.audio, t.subtitles, t.ratingsystem, t.rating, c.channelNickName, c.channelID, c.channelIcon, c.channelNumber, t.videoaspect, t.videocolor, t.starrating, t.actors, t.guests, t.director, t.producers, t.hosts, t.repeatshowing, t.programyear, t.scheduledEvent, t.ratingadvisory FROM userChannels u, tvlistings t, tvchannels c WHERE u.channelID = t.channelID AND t.channelID = c.channelID AND u.userid = 'blott' AND u.IsSelected = 1 AND u.IsAllowed = 1 AND c.viewHide = 0 AND ( (t.starttime >= #2007/10/20 15:00:00# AND t.starttime <= #2007/10/20 17:59:00#) OR (t.endtime >= #2007/10/20 15:01:00# And t.endtime <= #2007/10/20 17:59:00#) OR (t.starttime < #2007/10/20 15:00:00# AND t.endtime > #2007/10/20 17:59:00#) ) ORDER BY u.SortOrder, t.channelID, t.starttime
        10/20/2007 3:01:32 PM HSTV SELECT t.ratingID, t.rating, t.hideRating, u.IsAllowed FROM tvratings t, userratings u WHERE t.ratingID = u.ratingID AND u.UserID = 'blott'
        10/20/2007 3:01:33 PM HSTV GenPage: name: pg = value: hstvtuner
        10/20/2007 3:01:33 PM HSTV SELECT UserID FROM userOptions WHERE OptionName = 'pgprivtvadmin' AND OptionValue = '1'
        10/20/2007 3:01:35 PM MOTION >>>>>>>> Motion Detected with Kitchen Motion - No Motion (00:00)
        10/20/2007 3:01:35 PM HSTV PagePut: name: channelID = value:I19548.labs.zap2it.com
        10/20/2007 3:01:35 PM HSTV PagePut: name: pg = value:hstvtuner
        10/20/2007 3:01:35 PM HSTV PagePut: name: ref_page = value:hstv
        10/20/2007 3:01:35 PM HSTV PagePut: name: tunenow.x = value:33
        10/20/2007 3:01:35 PM HSTV PagePut: name: tunenow.y = value:15
        10/20/2007 3:01:35 PM HSTV SELECT optionValue, optionName FROM userOptions WHERE optionName = 'tuneItem' AND userID = 'blott'
        10/20/2007 3:01:35 PM HSTV SELECT 'app' as tbl, appID as ID, padTime, runOrder FROM deviceApp WHERE deviceID = 7 UNION SELECT 'ir', irID, padTime, runOrder FROM deviceIR WHERE deviceID = 7 UNION SELECT 'plugin', pluginID, padTime, runOrder FROM devicePlugin WHERE deviceID = 7 UNION SELECT 'speak',speakID, speakEarly, runOrder FROM deviceSpeak WHERE deviceID = 7 UNION SELECT 'script', scriptID, padTime, runOrder FROM deviceScript WHERE deviceID = 7 ORDER BY 3 desc, runOrder
        10/20/2007 3:01:35 PM HSTV SELECT c.channelID, c.channelnumber, c.channelname, c.channelNickName, l.title, l.episode, l.category, l.starttime, l.endtime, l.description, r.rating, r.speakRating FROM tvListings l, tvChannels c, tvRatings r WHERE l.channelID = c.channelID AND l.rating = r.rating AND c.channelID = 'I19548.labs.zap2it.com' AND l.starttime < Now() AND l.endtime > Now()
        Hope this helps!
        Bill
          This is copy and paste from a previous post hence the 10/8 date.
          Looks like no IR is being sent.
          10/8/2007 3:46:08 PM - HSTV - PagePut: name: channelID = value:I11297.labs.zap2it.com
          10/8/2007 3:46:08 PM - HSTV - PagePut: name: pg = value:hstvtuner
          10/8/2007 3:46:08 PM - HSTV - PagePut: name: ref_page = value:hstv
          10/8/2007 3:46:08 PM - HSTV - PagePut: name: tunenow.x = value:30
          10/8/2007 3:46:08 PM - HSTV - PagePut: name: tunenow.y = value:8
          10/8/2007 3:46:08 PM - HSTV - SELECT optionValue, optionName FROM userOptions WHERE optionName = 'tuneItem' AND userID = 'johnnyb'
          10/8/2007 3:46:08 PM - HSTV - SELECT 'app' as tbl, appID as ID, padTime, runOrder FROM deviceApp WHERE deviceID = 5 UNION SELECT 'ir', irID, padTime, runOrder FROM deviceIR WHERE deviceID = 5 UNION SELECT 'plugin', pluginID, padTime, runOrder FROM devicePlugin WHERE deviceID = 5 UNION SELECT 'speak',speakID, speakEarly, runOrder FROM deviceSpeak WHERE deviceID = 5 UNION SELECT 'script', scriptID, padTime, runOrder FROM deviceScript WHERE deviceID = 5 ORDER BY 3 desc, runOrder
          10/8/2007 3:46:08 PM - HSTV - SELECT c.channelID, c.channelnumber, c.channelname, c.channelNickName, l.title, l.episode, l.category, l.starttime, l.endtime, l.description, r.rating, r.speakRating FROM tvListings l, tvChannels c, tvRatings r WHERE l.channelID = c.channelID AND l.rating = r.rating AND c.channelID = 'I11297.labs.zap2it.com' AND l.starttime < Now() AND l.endtime > Now()
          John
            On the User Options page there is a dropdown for you to select a channel Tune device. This allows each user to select their own.
            So one user can select the Living Room Satellite, another user can select Bedroom TV and the grid page will know which device to use.
            Can you guys make sure you have selected a device, please.
            If you have, and it's still not sending IR, go to the control item setup for your IR and screen capture it and post it here so I can see how you have it setup.
            Jeff Farmer
            HS 3, HSPhone
              I don't have this option on my user page. Perhaps I do not have the latest version. Where can I get the latest if this is the case? I just checked the update page but HSTV does not appear.
              A screen shot of my ir control setup page is attached. I have tried omitting the power_on command to record by simply leaving the vcr on prior to the record time. Still no luck.
              Mark
                Jeff,
                Do you use the usbuirt or something else
                John
                  Jeff,
                  See the attached file for my settings.
                    masman,
                    Look at the times you have set for the IR.
                    1AM to 1AM. If that is how you actually have it set then it would never send the IR because it won't ever be greater than 1AM and less than 1AM.
                    For those of you that don't have the Channel Tune Device option, take a look at your control items. Do you have any that are setup as a Watch type?
                    If not, then the option won't show, so on the grid page you won't be able to click the channel icon to change the channel. It wouldn't know where to change the channel.
                    Jeff Farmer
                    HS 3, HSPhone
                      masman,
                      What should this be set at to run it 24/7? I put in a small window of time and was able to fire the IR but something like:
                      Enable: 12:59 AM
                      Disable: 12:58 AM
                      Does not work.
                      Good luck to the KC Chiefs....this week, but Nov. 4th I'll be rooting against them.
                      Packer Fan
                      John
                        masman,
                        I changed the time as shown below. Still, I cannot record. I do not get any ir transmission at all.
                        Mark
                          Try something like 1 minute past your computer time for enable and 3-4 hours later for disable time. Update and then wait for your computer time to reach what you have set and then try sending the ir.
                          John
                            Tried. No help. I really don't think that hstv is generating any ir strings to send. The control screen does not show any ir strings at all. See below. And this has been true no matter what settings I use in the control setup screen.
                              Maybe you need to add a watch item. I have not moved on to the record functions yet.
                              John
