Channel Icons
  • Channel Icons
    How do I get to the screen that allows me to input channel nicknames and icons?
    Click on the buttons
    TV admin,
    data,
    channels
    Jeff Farmer
    HS 3, HSPhone
      I had a problem not being able to get to this page. I believe it was due to too many channels downloading from schedules direct. I was downloading everything dish had to offer. Changed it to about 30 or so and all is well. I will gradually increase the number of channels....eventually.
      John
        Looks like I must be downloadeing too many channels. I can't get to that page.
          I can't figure out why you guys are getting errors with large amounts of channels. My test data has over 100 channels.
          Look in the ini file and see if you have a setting called
          chanEditPerPage
          It would be in the Settings section.
          If so, what is it's value? Is it blank or just not there?
          Jeff Farmer
          HS 3, HSPhone
            Thankjis for the help Jeff.
            here is my config file:
            hspi_hstv.ini
            [Integration]
            New Plugin=
            AB8SS.SetSpeakerPattern=AB8SS!SetSpeakerPattern!Pattern~text box~1~~11111111A~1!SetSpeakerScene~textbox~1~~~1
            mcsAudrey.AudreySpeak=mcsAudrey2!AudreySpeak!Audreys~textbox ~1~~~1!Speak String~textarea~2~~~1
            mcsAudrey.AudreySounds=mcsAudrey!AudreySounds!AUdreys~textbo x~1~~~1!Sound~dropdown~2~Cancel;0|Check;1|Copy;2|Cut;3|Delet e;4|Help;5|Major;6|Close;7|Open;8|High;9|Low;10|Paste;11|Pri nt;12|Down;13|Up;14|Snap;15|Warn;16|Sleep;17|Wake;18~~0
            mcsAudrey.AudreySoundsVolume=mcsAudrey!AudreySoundsVolume!AU dreys~textbox~1~~~1!Volume Level~dropdown~2~0;0|10;10|20;20|30;30|40;40|50;50|60;60|70; 70|80;80|90;90|100;100~80~0
            Message Server.messagetoclient=Message Server!messagetoclient!Message~textarea~1~~~1!Title~textbox~ 2~~~1!Message Type~dropdown~3~None;0|Info;1|Alert;2|Error;3~1~0!Message Box~radio~4~True;True|False;False~True~0!Tray Balloons~radio~5~True;True|False;False~False~0!Client Name or IP~textbox~6~~~1
            Message Server.messagewave=Message Server!messagewave!File Name~textbox~1~~~1!Client Name or IP~textbox~2~~~1
            Message Server.TouchPad_MessageToClient=Message Server!TouchPad_MessageToClient!Message~textarea~1~~~1!Clien t Name or IP~textbox~2~~~1
            Message Server.SAPI_MessageToClient=Message Server!SAPI_MessageToClient!Message~textarea~1~~~1!Client Name or IP~textbox~2~~~1
            Ledam.SetMessage=Ledam!SetMessage!Handle~textbox~1~~~1!Messa ge~textarea~2~~~1!Display Time~textbox~3~~~1!Priority~textbox~4~3~~1!Beep Length~textbox~5~3~~1!Beep Count~textbox~6~3~~1!Repeat Count~textbox~7~3~~1!Sign ID~textbox~8~~*~1!Delete After Display~dropdown~9~Yes;True|No;False~False~0!Auto Start~dropdown~10~Yes;True|No;False~False~0!Start Paused~dropdown~11~Yes;True|No;False~False~0!Start Stop~textbox~12~2~~1!Fixed Label~textbox~13~~~1!Run Order~textbox~14~3~~1!Memory Allocation~textbox~15~3~~1!Beep Frequency~textbox~16~3~~1
            mcsAudrey2.AudreySpeak=mcsAudrey2!AudreySpeak!Audreys~textbo x~1~~~1!Speak String~textarea~2~~~1
            [Settings]
            mysqlconnect=DRIVER={MySQL ODBC 3.51 Driver}; SERVER=MyServer; PORT=3306; DATABASE=MyNameOfDatabase; USER=MyUserID; PASSWORD=MyPassword;
            sqlserverconnect=Provider=SQLOLEDB;Data Source=MyServer;Initial Catalog=MyNameOfDatabase;Trusted_Connection=yes
            accessconnect=Provider=Microsoft.Jet.OLEDB.4.0;Data Source=c:\Program Files\HomeSeer 2\data\hstv\hstv.mdb
            debug=1
            dbtype=Access
            dbname=Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\Program Files\HomeSeer\data\hstv\hstv.mdb
            daysahead=2
            redownload=0
            listingstype=tv_grab_na_dd
            multiproviders=
            installpath=C:\Program Files\HomeSeer\data\hstv\xmltv\
            schedNextEnd=10/30/2007 2:50:00 PM
            showSQLSvr=0
            defuser=blott
            playQuote=0
            databasename=
            useVR=1
            numdayshistory=
            numdaysevents=7
            defRatingID=3
            [Install]
            installStep=12
            installDone=1
            [New Channel]
            Channel ID=
            Channel Name=
            Channel Number=
            [DataDirect]
            expireDate=10/7/2008 12:00:00 AM
            [TTS]
            LastSpoken=Tuning to channel 908 now to watch Inside Edition.
              Go to your channel edit page and post a screen shot. That will help me narrow down some what where on the page the error is happening.
              Jeff Farmer
              HS 3, HSPhone
                How do I attach a screen shot within this message?
                  Now working
                  At Jeff's suggestion I checked the TV:Channels Table.
                  I had a piece of stray data in one of the channels channeldevcode field in the tvChannels table. . I removed it and I now have visibility to the channels in HSTV.
