Channel 121 won't add
  • Channel 121 won't add
    I can add and remove channels in the Admin screen OK and then under my user screen OK except for this one channel. It shows up correctly in the channel selector screen with a check mark next to it but will not display on the listing.
    John
    Try this first.
    Remove the checkmark and click save. Then click to add the checkmark and click save.
    Some of the items on a page are defaulted for the webpage but still need to be saved once to update the database.
    Jeff Farmer
    HS 3, HSPhone
      All ready tried that, tried again just to be sure. Nope, still does not show up in the listing.
      John
        When adjusting the config file for day light saving time I noticed channel 121 was not there. I added it and now it shows in my listing.
        John
          Can someone tell me where this file is located?
          Don
            One thing that might help. When you run the XMLTV config, make sure that you set the option "Do you want to skip some channels" to no.
            That way the channel doesn't need to be in the config file for it to download.
            You control the channels to be downloaded at Schedules Direct.
            Jeff Farmer
            HS 3, HSPhone
              The conf file should be in the folder HomeSeer 2\data\hstv\xmltv\.xmltv
              If you find that you have more than one, the easy way to setup the correct one is to go into the HSTV admin. Click on the Integration button, then click on the XMLTV button. Near the bottom of the page is a button labeled XMLTV Configure. Click that. A DOS window will open on the server running the configure program.
              Follow that step by step to setup the conf file.
              Jeff Farmer
              HS 3, HSPhone
