Here are the steps I took.
- Install from updater.
- Got to the tv admin webpage (mines running on port 8000)(set "get listings for 7 days", click save at bottom)
- Go to Control Panel > Admin Tools -> System DSN -> HSTV -> Configure -> hstv97.mdb -> ok -> ok
- Run command line stuff
- enter time zone
- sign up with ZapIt
- enter login info
- install all channels
- program ends, appears to be finished
- Go to homeseer, execute HSTVDownloadMulti
- command line program windows launch and exit.
- Check C:/Program Files/Homeseer/data/hstv/listings/ and note that only the dtd file is present
- swear a lot because no xml files reside there as the installation instructions say.
- Delete all HSTV files, ini files, and OCDB connections.
- Reinstall from updater and repeat the above steps 4 to 5 more times or until you feel extremely bored.
How can I get HSTV to work with Homeseer on a WinXP machine. Is it possible?
- John
- enter time zone
- enter login info
- John
