2 lineups ??
    2 lineups ??
    Is there a way to have two line ups for HSTV. I have direct TV working with HSTV and would like to add the off air local HD TV channel line up to HSTV. Can this be done?
    HS2 Environment
    Zotac 1.83 GHz Quadcore
    HomeSeer Way2Call
    Netiom-Xap board
    opnode 1-wire 1.2.7
    Plug-In's
    WeatherXML 1.0.0.32
    Pwr Link USB 1.0.0.13
    mcsTemp V6.2.0.14
    mcsXap V3.0.0.0/3.0.0.20
    IM Connector 4.87.2.5
    Sip Connector 2.56.2.4
    RFXCOM 15.0.0.22
    Odroid X2
    Asterisk 11.5.1
    FreePBX 2.11.0.42
    WebMin 1.720
    Xap Switchboard by Mi4
    There is no place Like 127.0.0.1
    I think you'll find HSTV 3.0.1.29059 has this facility.
      I sent a new version to Wadenut a while back to test the duplicate provider and then forgot to post it.
      I have class tonight, but when I get done I will add the new version to the zip file and make it available.
      I'll post here when it's ready to download.
      Jeff Farmer
      HS 3, HSPhone
        Ok thanks I will give it a whirl after you get it posted. Thanks!
        HS2 Environment
        HomeSeer Way2Call
        Netiom-Xap board
        opnode 1-wire 1.2.7
        Plug-In's
        WeatherXML 1.0.0.32
        mcsTemp V6.2.0.14
        RFXCOM 15.0.0.22
        Odroid X2
        Asterisk 11.5.1
        FreePBX 2.11.0.42
        WebMin 1.720
          Go to this thread: http://forums.homeseer.com/showthread.php?t=123533
          Download the zip file. For this change you can just pull the hspi_hstv.dll file and place it in the homeseer2 directory. Let it overwrite the old one.
          You will need to stop HomeSeer to copy the file. Restart HomeSeer and go into HSTV Admin. Integration, XMLTV.
          You will need to run the XMLTV config to setup the config file for the second lineup.
          Enter the name of the second config file in textbox labeled 'Enter config file name for one additional provider'. Do not add the .conf to the file name.
          Jeff Farmer
          HS 3, HSPhone
            I'd forgotten I was the alpha tester on that. Worked for me.
