New lineup queston, need a little assistance.
  • #16
    Originally posted by wayneway View Post
    nightwalker,I never had that problem but some years back i read post about hstv data files geting too big. try this go in to hstv admin general options change form LOWLEVEL LOGGING to
    HIGHLEVEL LOGGING, see if that help. one more did you upgrade from hs 2 to hs pro.
    There's something I haven't tried. I'll give it a shot and see. For now I'm staying at HS Standard so nothing has changed, only my TV lineup.
    Marty
    XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
    Playing with HS3 a bit but it's just play at this point.
    • #17
      I think they were talking about compacting the database which I just did reducing it from almost a gig to 5 megs.
      I see I still have some really old channels in my lineup. Its not a big deal but I could try to delete them from the database. If that would be easier?
      Unfortunately I am out of time tonight to do that - close h/s move the file to a machine that has access, delete records and then re-import all the data.
      John
      • #18
        Changing the logging didn't really do anything but give me lots of entries in my HS log about HSTV. I tried deleting and re-creating the conf file, no differance. I tried deleting the database, but it doesn't get recreated at startup, so nothing worked and I could find no way to create one, I suppose it's created during the setup.
        The only way I see to do this is to manually go in and compare what I have now, with what I used to have and delete channels and rename others. This will take weeks and weeks. It just can't be the only way.
        Now that I think about it, there is an empty database in the install files. I wonder what would happen if I dropped that in there?
        Marty
        • #19
          Can you open the database? I would try removing channels from there. If you delete it you will lose some of the configurations you have set
          John
          • #20
            If I shut down HS I can open it, until then it's locked. It may work to edit it to get rid of stations but that goes back to the same problem, there are about 3000 of them in there that would have to be edited manually.
            Marty
            • #21
              I just think it would be a lot easier to delete out a bunch of rows in the table. Thats if it works the way you want and it also keeps them out of the HSTV webview. I would delete out chunk and see what happens. And maybe first make a copy of the original database.
              All those stations must take a while to download??
              Oh and Im just guessing here so please do not hold me responsible for any bad stuff.
              John
              • #22
                I think we're all guessing about what will work.
                I think I got it but this solution may not be for everyone depending on how complicated your setup is.
                I deleted the "tv_grab_na_dd.conf" file and did the xmltv setup again. This allowed it to make sure it was only downloading the shows from the current lineup.
                I shut down HS and deleted the hstv database and replaced it with the empty database from the hstv3 install file. I re-did my setup. Things are now back to being as they should be. Granted I have a very simple setup of HSTV, I really only use it to allow my wife to pop-up a TV Guide on a HST screen. Those with complicated setups with recordings, and reminders etc may not want to do this.
                It's not a perfect solution for everyone but it has worked for me to get rid of all the old channels that were clogging up the channel selection screens. Before there were wrong channel numbers pointing to wrong station callsigns etc.
                Hopefully the next time Jeff gets on here he can detail the correct procedure to approach a new channel lineup when you switch TV providers.
                Marty
                • #23
                  I'm not sure why the new channels wouldn't show up on the channel editor unless the channel ID is the same.
                  For others who might be having this problem, I would suggest that rather than deleting the entire database, try deleting all the data in the tvChannels table. Then run the import event and see if the channels get added. Once they are showing on the channel editor, you most likely would need to go through the admin screens for your users and select which channels they are allowed to choose from. Then each user would need to re-select the channels they actually want in their lineup.
                  Jeff Farmer
                  HS 3, HSPhone
                  • #24
                    Oh sure, now you show up.
                    Seriously it's not that the channels were not showing up, it was that since I went to a completely different provider there were not 2585 new channels showing along with the old channels still there. At least from my perspective, since i didn't really have a complicated setup it ended up being easier to just reset it all and get rid of the old channels and only have to deal with the new ones.
                    If I had a more complicated setup I might have gone a different way.
                    Marty
                    • #25
                      I wanted to test the above idea so I deleted all the channels in the tvChannels table. Then ran the events to download and import the data. It added all the new channels. You do lose the settings for the image and any virtual devices you had setup, but you can add them back with the new channels.
                      Then run through the user settings to make sure everything is set the way you wanted.
                      Jeff Farmer
                      HS 3, HSPhone
                      • #26
                        Apparently I deleted more than I really needed to getting it back to something managable, but it's done now and back in the pink!
                        Marty
