Altering HSTV Virtual Devices?
  • Altering HSTV Virtual Devices?
    In my setup, HSTV creates and uses 7 (or 8?) virtual devices ]1 thru ]7 (and ]8 ?). Is there any way to change the virtual device names used? These particular ones happen to collide with the HomeVision Relay Out 1-8 devices.
    The first time a plugin starts it is assigned a code for it's devices. HSTV stores that code and then uses it each time after that.
    I think you can delete the following from the settings.ini file.
    [hspi_hstv]
    gBaseCode=93
    That should free up that code and should assign a new one the next time HSTV starts.
    Jeff Farmer
    HS 3, HSPhone
