Hstouch
  • #16
    Originally posted by travisdh View Post
    I am slowly moving forward in getting this set up for my hstouch system, thereby hopefully increasing the WAF, and allowing me to get even more automation stuff
    I have turned off the hstv menu bar, and the category legend stuff so that part is working fine, however I am unsure of how to turn off the homeseer web server menu bar, so that only the tv listing grid is showing, but none of the homeseer server status, events, control etc headers.
    Id appreciate any thoughts you might have as to how best to achieve this, so i can just have the listings table embedded in a hstouch textbox (html).
    (Marked the section i don't want to show in the attached picture in red)
    When I get back from my errands this is one of the items on my to do list.
    Jeff Farmer
    HS 3, HSPhone
    • #17
      Originally posted by CFGuy View Post
      Check on the General Options and make sure you have Access selected as the Database Type. Also post or email your Connection String which is right below the Database type.
      I have to run some errands this morning but when I get back I have the rest of the day to help.
      Thanks. I had already deleted everything and started from scratch. I had had like a thousand channels to get data from and that may have been too many. When I started over I limited it to like 15 channels and now working. thanks again.
      • #18
        Sorry to keep bugging you but this is a great plugin. My goal is to look at a guide on my smart phone using hstouch and then when you press the channel my tv will go to that channel. I have a number of events set up in homeseer that use TCP to control the IR for my TV and other components. For instance, I have an event to watch NFLNET on 169 and my Tivo will change the channel to 169. Looks like though on the "Control" tab there isn't a way to run a homeseer event. Should I use scripting to run a homeseer event?
        • #19
          You can do more channels. Just schedule the downlaod, import xml and import data events farther apart. I have the number of days ahead set to 13. I use Dish for my tv so I have a lot of channels being imported.
          I have the following:
          HSTV Step 1: Download XML Files set to run at 4:46 AM
          HSTV Step 2: Import XML FIles set to run at 5:06 AM
          HSTV Step 3: Import Data set to run at 5:32 AM
          Jeff Farmer
          HS 3, HSPhone
          • #20
            Click on the Button HSTV Admin, then click on the About button.
            On the page there is a link that has the text HSTV for large displays in front of it. Click the link /hstv?pg=display
            That will give you a listings with no buttons at the top. The style sheet is designed to make everything large with this look but you can modify the style sheet to shrink it down to what ever size you want.
            Jeff Farmer
            HS 3, HSPhone
            • #21
              I think you would be better off using a script. In the Control Item you can setup the script name and the parameter items to send to your script. Then in the script you can check either the channel ID, number or name to change to that channel. That way you don't need a separate event for each channel.
              Jeff Farmer
              HS 3, HSPhone
              • #22
                hstouch screen
                I made this screen using the data from your plugin. It's pretty ghetto though. You think this is something that could be done and then be able to scroll through all the channels and descriptions like an actual guide. Then seeing something you like, pressing it and it comes on?
                • #23
                  That is quite impressive, any chance you can share how you got that layout working, did you use a script to pull what was currently on with each channel?
                  HS3 PRO, Win10, WeatherXML, HSTouch, Pushover, UltraGCIR, Heaps of Jon00 Plugins, Just sold and about to move so very slim system.
                  Facebook | Twitter | Flickr | Google+ | Website | YouTube
                  • #24
                    Not sure if I had to but I used Blade's script so that the formatting would be ok for the hstouch as far as the tv data goes. But like I said it was ghetto. I just manually added all the buttons, put blade's script in the text box of each button and just dragged the image logo from the hstv logo folder...
                    • #25
                      I'm not very good with HSTouch yet. I'm out of town tomorrow but will look into this on Monday to see what I can come up with. I know that HSTouch has the new feature where you can use a file on the server to populate the fields so that might be the way to go.
                      Would it work for you if the Channel Logo button called a script with a parameter of the channel number?
                      Jeff Farmer
                      HS 3, HSPhone
                      • #26
                        For my setup it would work better if the logo called an event as I already have all my channels as homeseer events. Thanks for looking into it! I'm actually surprised nobody has done something like this before as far as I can tell...
                        • #27
                          Just to make sure, you guys are looking for a web page to use as an HTML page in the HSTouch pages.
                          Jeff Farmer
                          HS 3, HSPhone
                          • #28
                            That would be fine with me. I'm just looking for a scrollable guide that is somewhat interactive, ie can go to that show by pressing a button.
                            • #29
                              When you say scrollable do you mean a swipe gesture or via scroll bar?
                              John
                              • #30
                                I think a scroll bar is too cumbersome and not easy to use on a phone. A swipe gesture makes more sense to me.
