HSTV2 database connect problem
  • HSTV2 database connect problem
    After 10 years running win2003 I switched to Windows homeserver 2011 64 bits.
    Homeseer is running but I have a problem with the HSTV.MDB
    I get the following error when I go to for instance events:
    Script error: [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
    if Request.Form.Item("createevents") <> "" Then
    hs.launch hs.GetAppPath & "\data\hstv\hstv.exe","runevents",""
    Seems like HSTV can't open the database?
    Peter
    http://ohh.pcgsm.nl
    Look on the hstv general options page and check what you have entered for the connection string. Make sure the pathway is correct to the database.
    Also, check the database to see what size it is. If it's near 2 gb, then run a repair and compact.
    Jeff Farmer
    HS 3, HSPhone
      Where can I find the general options page?
      I have the admin page with ODBC name : DSN=hstv
      HS is now running in C:\Program Files (x86)\HomeSeer 2\
      On my old PC it was C:\Program Files\HomeSeer 2\
      Can that be the problem somewhere?
      Peter
      http://ohh.pcgsm.nl
        Sounds like you are running a really old version of hstv.
        The version where you just entered a datasource name requires you to go into Control Panel, Administrative Tools, ODBC DataSources and create a datasource called HSTV that points to the database.
        Jeff Farmer
        HS 3, HSPhone
          created the datasource and everything is ok now.
          Thanks!
          Peter
          http://ohh.pcgsm.nl
            Glad to hear it!
            Jeff Farmer
            HS 3, HSPhone
