Error in Log
  • Error in Log
    I keep getting this error and I can't track the cause down:
    I think its related to this thread.
    http://forums.homeseer.com/showthread.php?t=158430
    Jeff Farmer
    HS 3, HSPhone
      I sent you the database. Can you change it? I don't have microsoft access and the other way I changed it in the past isn't working.
        Sent you an email.
        Jeff Farmer
        HS 3, HSPhone
          Error in Log
          Sent you an email.
          Thanks Jeff. I ended up just swapping out the database file from a backup of homeseer when I knew it was working fine (i should have thought of that in the first place). I wonder why that "required" would have changed all the sudden. It's almost like the database file became corrupted because I couldn't open it with microsoft access (i trialed it). Working fine now. I've noticed that homeseer becomes essentially unresponsive when hstv is importing data. Have you noticed this? Any events don't occur until after it's finished...
            How big was the database that was causing the error?
            If it was getting close or over 2 Gigs, then that was most likely the cause.
            An access database needs to be compacted every so often.
            There should be a HSTV event action that you can run to compact the database.
            I would suggest to run it after the data import has finished.
            Jeff Farmer
            HS 3, HSPhone
              Error in Log
              It's only 19 MB. Also, i do have the compact database event running automatically after the other events.
