Scheduled Favorites stop announcing.
    I have been having issue now with the favorites stopping to announce and I have have to cycle HS and they will start working again. I turned up logging to detailed and have found the last 2 days it appears that the one minute check stops each morning. I have included the log information from this morning:
    3/23/2013 5:51:00 AM HSTV Checking for Scheduled Actions
    3/23/2013 5:51:00 AM HSTV SELECT d.appID as ID, 'app' as runTable, d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM scheduledFavs s, userFavs u, deviceApp d WHERE s.favID = u.favID AND u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',-(d.padTime),s.starttime) = '3/23/2013 5:51:00 AM' UNION SELECT d.emailID, 'email', d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM scheduledFavs s, userFavs u, deviceEmail d WHERE s.favID = u.favID AND u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',-(d.emailEarly),s.starttime) = '3/23/2013 5:51:00 AM' UNION SELECT d.irID, 'ir', d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM scheduledFavs s, userFavs u, deviceIR d WHERE s.favID = u.favID AND u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',-(d.padTime),s.starttime) = '3/23/2013 5:51:00 AM' UNION SELECT d.scriptID, 'script', d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM scheduledFavs s, userFavs u, deviceScript d WHERE s.favID = u.favID AND u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',-(d.padTime),s.starttime) = '3/23/2013 5:51:00 AM' UNION SELECT d.speakID, 'speak', d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM scheduledFavs s, userFavs u, deviceSpeak d WHERE s.favID = u.favID AND u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',-(d.speakEarly),s.starttime) = '3/23/2013 5:51:00 AM' UNION SELECT d.pluginID, 'plugin', d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM scheduledFavs s, userFavs u, devicePlugin d WHERE s.favID = u.favID AND u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',-(d.padTime),s.starttime) = '3/23/2013 5:51:00 AM' UNION SELECT d.irID, 'irstop', d.runOrder, s.favID, s.starttime, s.channelID, s.scheduledID, u.RepeatType FROM tvListings l, scheduledFavs s, userFavs u, deviceIR d WHERE l.starttime = s.starttime And l.channelID = s.channelID And s.favID = u.favID And u.deviceID = d.deviceID AND s.isActive = 1 AND u.isActive = 1 AND DateAdd('n',d.padTime,l.endtime) = '3/23/2013 5:51:00 AM' ORDER BY s.scheduledID, s.FavID, d.runOrder
    3/23/2013 5:51:00 AM HSTV Array Rows: -1, Cols: 7
    3/23/2013 5:51:01 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:51:11 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:51:19 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:51:27 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:51:42 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:51:49 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:51:57 AM X10 Received M5 (Basement Computer Area Computer Desk (MS)) M On
    3/23/2013 5:52:00 AM Event Event Trigger "HSTV Step 4: Compact Database"
    3/23/2013 5:52:00 AM Event Running script statement immediately: &hs.Plugin("HSTV").compactAccessDB()
    3/23/2013 5:52:00 AM HSTV Database Size Before Compact: 18260 KB
    3/23/2013 5:52:00 AM HSTV Compact C:\Program Files (x86)\HomeSeer HSPRO\data\hstv\hstv.mdb
    3/23/2013 5:52:00 AM HSTV HSTV will stop checking for Scheduled Favorite Events
    3/23/2013 5:52:00 AM HSTV Database Size After Compact: 18260 KB
    3/23/2013 5:52:00 AM HSTV Finished compacting Access database
    3/23/2013 5:52:00 AM HSTV HSTV will start checking for Scheduled Favorite Events
    The entry for 5:51:00 AM is the last one that shows up for "Checking for Scheduled Actions".
    I can try disabling the compact event for a while and see if that helps for now. I'm guessing it will. Any help would be appreciated.
    Jeff
    Go ahead and turn off the compact database for one day and let me know. That will narrow down where in the code I need to look.
    Jeff Farmer
    HS 3, HSPhone
      Jeff,
      I disabled the compact event and the announcements/scheduled items worked fine through the night and until this morning. So I manually kicked off the compact event and sure enough the 1 minute update checks stopped right after it completed.
      Jeff
        Found the bug.
        Version 3.1.6 is in the download thread.
        You don't need to do a full install. Just grab the hspi_hstv.dll from the zip file, stop HS, put the dll in the homeseer directory and restart HS.
        Jeff Farmer
        HS 3, HSPhone
          I have installed it tonight and turned the event back on.
          Jeff
