Still working??
    Still working??
    Hello,
    Is this plugin still working? And is it still supported?
    I just installed it on my hs3 machine. But I can't get any radio station to start playing.
    When I look in the log files the folowing is displayed:
    aug-15 21:31:51 Device Control Device: Luidsprekers (2- High Definition Audio Device) Radio Luidsprekers (2- High Definition Audio Device) Radio to Stop (4) by/from: CAPI Control Handler
    Non of the preset URLs work, also known working other URL's don't work.
    Used "http://playerservices.streamtheworld.com/api/livestream-redirect/RADIO538AAC.aac" to see if the plugin worked.
    I created my own 'launch VLC Media Player' events to play internet radio stations. Here is an example of iHeart 80's Radio
      Thanks, will work very well to start a radio stream.
      How do you stop the streaming?
      I was looking at command line options for vlc, apparantly vlc://quit should quit vlc but I can't get that working from an event.
      When I start another stream now it starts an extra instance of VLC and plays both streams at the same time.
        you are right, //quit does not work. I never noticed as I usually only listen to one station for hours.
        its not very elegant but you can precede the VLC launch for each station event with a taskkill /IM vlc.exe for the time being. It works but I know somebody will have a better way
