Can't connect to itunes - pairing problem
  • Can't connect to itunes - pairing problem
    Hi,
    I have HomeTroller Zee S2
    Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux
    ERROR Object synchronization method was called from an unsynchronized block of code.
    And then
    DEBUG at Mono.Zeroconf.Providers.AvahiDBus.RegisterService.RegisterDB us () <0x71f967a8 + 0x002a3> in :0 at Mono.Zeroconf.Providers.AvahiDBus.RegisterService.Register () <0x71f96540 + 0x00017> in :0 at Mono.Zeroconf.RegisterService.Register () <0x71f96508 + 0x0002b> in :0 at HSPI_ITUNES_DAAP.PairingServer.PublishService () <0x71f95450 + 0x0024b> in :0 at HSPI_ITUNES_DAAP.PairingServer.Start () <0x71f91460 + 0x0012b> in :0 at HSPI_ITUNES_DAAP.WebConfig.postBackProc (System.String page, System.String data, System.String user, System.Int32 userRights) <0x71f8f818 + 0x00263> in :0
    Can you please help? I installed the avahi as you wrote in the tutorial
    Managed to solve the issue. In case anyone else have same problem.
    You should copy Mono.Zeroconf.Providers.Avahi.dll to iTunesDAAP installation folder (in my case it's under /usr/local/HomeSeer/bin/iTunesDAAP/)
    I took this file from Airplay Speak plugin (same location under AirplaySpeak)
      I have fixed this issue in version 3.0.0.29 available here.
      Now all the needed dlls should be installed with the plug-in.
      Unconfigured PHP Module
