Question about TTS?
  • Question about TTS?
    Hi, if your playing a song thru your plugin and there's a TTS announcement, wil the plugin pause the music for the TTS?
    And also, can you call up a song or give instructions to the plug using VR?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    there is an option called "Pause when HS is speaking" which will pause iTunes for TTS and restart it after it's done.
    you can set up an event to play a specific song, artist, album or playlist using VR, but you can't use VR to play any song unless you have an event for each one.
      Spud,
      I purchased your iTunes plugin. I also want to have HS TTS play over my AirPlay speakers. Do I need your AirPlay plugin or will it work with the iTunes plugin?
      Michael
      HS3 Pro 3.0.0.470 | 849 devices | 349 events | OpenSprinkler | BLShutdown | EasyTrigger | NetCAM | Harmony Hub | Sonos | SDJ-Health | BLUPS | PHLocation | BLBackup | BLLock | Z-Wave 3.0.1.243 | weatherXML | Pushover 3P | Blue-Iris | AirPlaySpeak
        Originally posted by Rvtravlr View Post
        Spud,
        Yes for TTS you need the AirplaySpeak plug-in, the iTunes DAAP plug-in can only play what is in your iTunes Library.
