iTunes DAAP plugin now works with HSTouch Media API, finally!
  • #46
    Originally posted by tome10 View Post
    Well I installed the default player which seems to be working, but now I have a different issue. The plugin is not installing a speaker device for the tablet. Homeseer sees the speaker client, but the plugin is apparently not. I have reinstalled the plugin but did not fix the issue.
    I went through the list you had of compatible components, but some of the revisions were not available.
    Running:
    iTunesDAAP 3.0.0.29
    HSTouch Server 3.0.0.104
    Client Android 1.0.136
    Not sure what you expect; the plugin is not supposed to create a new speaker device for each HSTouch client, unless the tablet on which HSTouch is running is a Airplay speaker that is already controllable from iTunes.
    • #47
      ohh, I thought the Media API update just used the HSTouch Speaker clients outright. Forgive my ignorance, but what did the API update do exactly?
      • #48
        it allows to browse and select your music from HSTouch (using the "music selector" component)
        • #49
          Originally posted by spud View Post
          Have you tried to open mptest.xml as a new project in HSTouch Designer?
          If it is not working, it is easy to rerceate it from scratch:
          Create a new ListBox and set its "status tracking" property to Music / Music selector.
          Then create the buttons and labels and set their actions and status tracking with Music actions and associations (Current Track's Artist, etc...)
          [ATTACH]62640[/ATTACH]
          Thinking about purchasing this plugin. Thus far I have created a HS3 Touch (iPhone 7) screen by looking at the example given (a work in progress).
          If you look at the right side where I have a red circle - that is where I think there should/could be the "selector-slider" that I remember seeing in an older iPhone project from HS2. A simple thin scroll bar that displays A-Z, top to bottom.
          Could someone please point me the right way to help figure this out so I can have the scroll?
