New to iTunes DAAP
  • New to iTunes DAAP
    Just started the 30 day trial on your plugin. It really works well. Thanks for your efforts on this.
    The only thing I have seen so far is when I create an event and tell it to play a playlist. After I choose a playlist from the drop down menu, which shows all my playlists from iTunes, the event is showing a playlist ID not the name of the playlist. See below.
    Is there something I missed in order to display the playlist name. By the way, the playlist name shows correctly in the Device Management view. I have version 3.0.0.23 installed
    [ATTACH]50130[/ATTACH]
    You did not miss anything, I have just been lazy when implementing this.
    The ID you see is what is stored in the database, so I need to find and display the associated playlist name. I will fix it in the next version.
    Note that if you open the action, you should see the name of the playlist.
      You are correct, when I open the option everything is displayed correctly.
      This is a really great plugin. I will definitely be buying this one.
      Many thanks
        it's fixed in version 3.0.0.26 available here
        Unconfigured PHP Module
