Activate Screensaver
    Is there a way that i can call an action in events that can activate the screensaver mode on a Kodi client 17.x or newer.
    I have Kodi on some Pi3 and they turn off the TV when the screensaver goes on (CEC control). So i would like to have an event that uses the screen saver mode to turn off the kids TV.
    How can i do this?
    you can try an event like this
    Kodi Action
    Action Type: GUI Activate Window
    Instance: your instance
    Window: screensaver
    But I doubt it does what you want. From my quick test it activates the screensaver, but then to deactivate it you need to send another GUI Activate Window action with Home as the Window parameter.
      Kodi Action
      Window: screensaver
      You are correct, is does not work.
      The screen just goes blank. So this function does not call the configured screensaver, as i have the screensaver configured as 'Dim'
      There must be another solution to call the configured screensaver.
      I have the screensaver set to 15min, so if kodi is not used for 15min, the TV is powered off.
      But would like HS to control it.
        Any comment on this.
        Can i activate the configured screensaver?
        Sent from my iPhone using Tapatalk Pro
          I couldn't find a way to activate the screen saver from the API
          However I find some simple script addon that allows you to send some CEC commands through the API: https://github.com/joshjowen/script.json-cec
          install the addon
          then from an HS Event action, use the Execute Addon action with
          id = script.json-cec
          parameters = {"command":"standby"}
          I haven't tested it, but it should work
            Thanks. Sounds a little complicated.
            But will give it a shot in the near future.
ID:	1430897 I used Jon00's Utilty Jon00RCC locally on my HS.Machine Then set up an event to run his script ..Check it out.
              Now when I walk into the room the screen saver turns OFF and I can See my Cameras without doing anything.. VERY NICE!
