I'm revising my Alpha 1 o
Comments...
It's working for me But I have some repeatable problem.
Often the initial start (pressing play on the remote) of a video is not being seen by the plugin. Thus, events are not triggering. But if I press Pause and start Playing again, the plugin sees it.
I'll turn on debug soon.
Sent from my SM-G950U using Tapatalk
Laest Kodi v18 build not working 100% with plugin
I've been on alpha 1 for a while now, the plugin is working well for me.Originally posted by skarragallagher View PostJust adding to this thread. I am a Kodi 18 early adopter because of the Netflix support. I have all my Rasberry pi and Windows PC running the Alpha builds.
I have noticed that several events that i have as well that used to run are now broken like: turn off living room lights when kodi changes to playing. And also control a zwave binary switch when kodi disconnects.
Spud is there anything we can do to get this working short of reverting to Kodi 17. I think we are close to a beta release here. Any chance we can get a beta plugin that will work with the new JSON changes?
It looks like they are still adding breaking changes to the API, so I would like it to be a bit more stable before I take a look.
Let me know when v18 alpha2 is released.
Originally posted by OliP View PostCame here to start a new thread about upcoming leia api breaking changes, and found this thread.
Im keen to find as much info about this as possible as i have a seperate project that interacts with kodi the same way as this plugin and can also see breakages with my code base.
I've asked over on the kodi forum for more info on the change, and how we can get around it or if this is game over for remote control of kodi. i can't imagine that it would be, as it would break all the android / ios remotes out there that also use json to interact.
anyway, back to quietly reading along intently.
Originally posted by Ltek View PostI'm probably not going back to 17. There are several things in 18 that are better or fixed for me.
Still, if you could incorporate the change where a disconnect clears the child devices that would help us create more useful, and accurate, events for Kodi.
Thx
Originally posted by spud View PostI haven't tested Kodi v18 yet, but I saw it has some breaking changes in the JSON API.
I would advise to stay on v17 for now as v18 is still in Beta and months from being released.
Thx
See anything ? I installed an older version of Kodi v18 and it has no problem connecting. But, I'm still having a problem where it think it has been paused .. Triggering an event it should not be
Today's Log attached.
Figured out a few things...
1. The plugin Disconnects and will not reconnect on its own. And when it shows Connected, still acts like its not.
... I know this because soon as I removed the line from my Events that looked for it to be Connected (Condition = Connected), the events started firing.
2. After removing the 'Connected' Condition, my 'Pause' Event (see screen shot) would fire randomly. Thus, the plugin thought it was paused even though the Kodi Device still showed Playing.
I have a few suggestions based on this, which will also make thigns easier in Events...
When Kodi is disconnects, clear ALL devices... Status & Volume don't clear like the others do. This will fix it so we no longer need to check for connection in Events to be able to use the Status properly.
Homeseer Event Log & Plugin Log attachedAttached Files
Originally posted by Ltek View PostDo You mean did the IP Address change? No, that's I mentioned all the devices still updated fine.
Originally posted by spud View PostWhat is the ip of the Kodi instance with the issue?
If you use native triggers like "a device changes and becomes" and you say the device values are correctly updated then the problem is either with your event or with HS3 itself. The plugin does not have any control on that.
I will try to install Kodi v18 later this week.
